Front lower A-arm adjustment question
Old Jun 26, 2011 | 12:21 AM
IrishC6's Avatar
IrishC6
Default Front lower A-arm adjustment question
This weekend I had to replace the front lower passenger side A arm. The washers have hash marks for adjusting. The washers on the front side had paint marks to match up but the washers facing the rear did not. I had already pulled the bolts and washers before I noticed they were unmarked. How do I know if I have it adjusted properly?
Old Jun 26, 2011 | 12:34 AM
torquetube's Avatar
torquetube
Time for an alignment. Which is just as well, because you've replaced a major suspension component. Not to mention whatever event made its replacement necessary, which may also call for an alignment.
Old Jun 26, 2011 | 08:31 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
get it close by comparing the other side, is you can't get it on the alignment rack soon
pretty cool how the bolts area actually 'cams' and adjust camber/caster
now you have the actual experience for next time
To Front lower A-arm adjustment question
