Service Active Handling System
Old Jun 26, 2011 | 12:04 PM
iDoLiZeDbyALL's Avatar
iDoLiZeDbyALL
Default Service Active Handling System
This just popped up while I'm in the middle of a road trip. Should I be.overly concerned? I'm about 200miles from home. I haven't noticed anything performance wise with it.
Old Jun 26, 2011 | 04:08 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
http://forums.corvetteforum.com/c6-t...er-action.html
Old Jun 26, 2011 | 04:32 PM
iDoLiZeDbyALL
Thanks!
Old Jun 26, 2011 | 04:40 PM
Bill Dearborn's Avatar
Bill Dearborn
Don't let that thread scare you. When you see the message that means the system has shut itself off. The unusual happenings all occur when the system is working and does something weird just before the message shows up. Once the message is being displayed the system is off. If you have a constant message showing up the system is definitely off. All it means is you do not have stability control which most people rarely need just driving down the highway.
Bill
Old Jun 26, 2011 | 04:52 PM
iDoLiZeDbyALL
Bill
I see. It happend when I pulled out on the highway after stopping to let the wifey take some pics. I was at WOT, shifted through the first 4 gears with no problem, once I shifted into 5th...it came on! I pulled off the road into the next gas station and read through my owners manual and it says to take it to get it serviced. I drove it home and the only thing I noticed was it felt like the brakes would grab when I would start in 1st or 2nd. Like a grinding noise for a sec then it would go away.
To Service Active Handling System
