flushed brakes & now get warning
What did I do wrong (hope not the DOT 4), or do I just need to find someone who can clear the codes ?
Thanks for the help.
Since you were working on the car I would suspect something got bumped or disconnected. Here is what the Check Brake Fluid message means:
Brake Warning System Description and Operation
Brake System Indicators and Messages
Brake Warning Indicator
The instrument panel cluster (IPC) illuminates the brake warning indicator when the following occurs:
• The IPC detects that the park brake is applied. The park brake switch signal circuit is pulled to ground.
• The IPC detects a low brake fluid condition. The brake fluid level sensor signal circuit is pulled to ground for 15 seconds.
• The electronic brake control module (EBCM) detects a malfunction with the antilock brake system. The IPC receives a serial data message from the EBCM requesting illumination.
• The IPC detects a loss of communications with the EBCM.
• The IPC performs the bulb check at the start of each ignition cycle. The indicators illuminate for approximately 5 seconds.
• The Display Test is performed with a scan tool.
CHECK BRAKE FLUID Message
The driver information center (DIC) displays the CHECK BRAKE FLUID message when the IPC detects that the brake fluid level is below the normal operating range for 15 seconds.
Besides the wheels where the wheel speed sensors are located the only other place it sounds like you were working is at the master cylinder reservoir. If a wheel speed sensor was disturbed you would have more messages than you indicate you have seen and you wouldn't have a Check Brake Fluid message. It seems you may have disturbed the brake fluid level sensor which is on driver's side of the master cylinder reservoir. Make sure the connector is seated correctly. You can see it on the side of the reservoir if you look down past the windshield washer fill tube.
Bill
I went to autozone & advance auto to see if they could clear it, but az had no scanner for this, only engine codes, and adv auto could not get theirs to communicate with the car.
guess I will bite the bullet & see the dealer.
Thx all.
Thx all.
Bill
thx for the help.
