I was driving last week and the DIC started a stream of warning messages over and over until I returned home. Started with "Service Vehicle Soon" then "Service Active Handling" Service Traction Control, Service ABS, Service Fuel System and finally Low Fuel. Took it to dealer next morning and the Tech cleared the error codes and told me to drive it and bring back if problem returned. Today after an hour of driving the exact same thing happened again. While this is taking place the car performs as normal except the A/C quits working and the gauges read low.
The first thing to do is check your battery cables for tightness.
Second, load test your battery. Replace as needed.
Bad ground or intermittent battery connections could explain gages. AC coldness could be related ....freon needs a spark.
Else, that's a whole lotta messages. Lead me to think a computer module communication failure. I guess you should write down all the code that were set to analyze further.
Thanks for the response. Vehicle is 4 month old 2011 GS with 2K miles. Battery and charging system were checked during dealer visit. I tend to think it's a computer module problem and was wondering if anyone else has had this issue. Back to dealer in the AM and will report back.
