check engine light on car idels rough
Old Jul 2, 2011 | 05:42 PM
snapperfrog@aol.com's Avatar
snapperfrog@aol.com
Default check engine light on car idels rough
my 2008 ls3 is ideling rough and the cel is on i cleaned the k@n filter its was dirty but i took off the throttle body and with a flash light i could see what looked like a varnish and touched my finger on it and looked brown but smelled like gas 100 mile ago i stuck some injector cleaner in it and the code is 0174 lean bank2 do i need a new oxygen sensors and is 2 the left side help please
Old Jul 2, 2011 | 05:50 PM
VET4LES's Avatar
VET4LES
Are you sure everything is put back properly? A vacuum leak will cause a lean condition.
Old Jul 3, 2011 | 10:18 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Both sides can be running lean and Side 2 is just lean enough to set the P0174 code. Do you have a catch can? Any mods or is it still still stock other than the K&N?
Old Jul 3, 2011 | 12:38 PM
snapperfrog@aol.com
Default code po174
its has long tube headers it has 170 /0 thermastat it has varoom forces air and was tuned by drm 2 years ago and ran fine till now , no catch can added
Old Jul 3, 2011 | 02:34 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
It could be an O2 sensor and make sure there are no vacuum leaks. If you can, get it scanned.
To check engine light on car idels rough
