check gas cap
Old Jul 2, 2011 | 10:35 PM
donkt88's Avatar
donkt88
Default check gas cap
I got a 'check gas cap' message, put on a new one. Waited over night, and am still getting the message. Your thoughts.
Old Jul 3, 2011 | 02:00 PM
Vanoy's Avatar
Vanoy
I got this message a couple months ago and discovered the gas cap wasn't twisting on fully, as the teeth in the cap were wearing away. I got a new gas cap from my local Chevy parts department. After using the new cap, it was obvious to me the old cap was done.
Old Jul 3, 2011 | 02:41 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Did you start the car and run it a couple of times before you got the the light again or just wait overnihgt to check it again?
Old Jul 3, 2011 | 05:14 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Drive it first. It should turn off.
Old Jul 3, 2011 | 09:51 PM
etaylor14's Avatar
etaylor14
If it doesn't clear by itself have the codes checked and cleared. Autozone does it for free!!!!
Old Jul 3, 2011 | 11:02 PM
jrose7004's Avatar
jrose7004
You can clear the codes and reset it yourself.
Old Jul 4, 2011 | 01:33 AM
C6topless's Avatar
C6topless
if the cap is good, the code should clear itself after a while of driving.. usually in about 30 min... if it does not, you may need to get a new cap
Old Jul 4, 2011 | 07:43 AM
donkt88's Avatar
donkt88
Bill,
After installing a new cap, I weighted over night, started the car and am still getting the message. I forgot to mention that I got some gas at a independent station, close to the Mexican border before the check gas cap message originally appeared. Normally I use Chevron, but this was a panic buy, as I was on empty. Could bad gas cause the problem?
Old Jul 5, 2011 | 07:47 PM
ALS 08's Avatar
ALS 08
If I'm not mistaken its the loss of vacuum in the emissions system that triggers this code and not the actual cap itself other than its a bad sealing cap. or a leak in a hose that leads from gas tank to intake manifold will cause it also.
Had a check cap light in my Pick Up truck but I found the fault in a cracked hose behind the drivers front headlight area.
Old Jul 5, 2011 | 07:52 PM
ALS 08's Avatar
ALS 08
Originally Posted by donkt88
Bill,
Waiting overnight will have no effect, problem occurs while car is running. It will take some driving to clear it. The computer queiries the emissions system only occasionally and the next time it does it'll discover its working fine and light will go out.
Old Jul 6, 2011 | 12:46 PM
C6CorvetteZ51's Avatar
C6CorvetteZ51
Like ALS 08 said, it can any any air leak in the system. I had this problem on my 05 C6, it ended being a hose leak. Its most likely the issue if the cap is not the issue.
To check gas cap
