air bag light stays on
http://www.nhtsa.gov/Vehicle+Safety/Recalls+&+Defects
As a related issue, does anyone know if the air bag is operable with the air bag light on?
I'm sure these are the connectors you worked with. When I fixed my last air bag light a few days ago I knew it was fixed right away. Watch the air bag light on the dash when you press the start button. It will flash seven times and stop if everything is okay.
Make sure to file a complaint with the NHTSA. The link is in one of the above post. It only takes a few minuets. It's the only way we will get GM to fix this potential deadly defect.
Thanks for the tip on the seven flashes of the light.
I am the only driver, so the seat is almost never moved.
Onstar identified the light's error code as the driver-side side-impact (ie seat) airbag.
Initially, I simply disconnected then re-connected the pink plug in the photo above. That temporarily fixed the light for a trip or two. Did it again, same limited results, but I got the impression the plug pin connections might be the source of resistance. So, I disconnected it, blew out some accumulated dust, gave the pins a couple of quick brushes with a fine file (they look kind of oxidized), and ever so slightly tightened the pin sockets (they looked a bit loose) via a gentle squeeze with needle-nosed pliers. It's been quite a few trips since then with no error light so far, but not enough trips taken yet to definitively recommend these steps for the long term.
However, it's at least quick and easy to disconnect, visually inspect pins, and blow out any dust/crud.
One thing that strikes me is that even though there are about the same number of pins in that plug as in the 3LT rearview mirror plug, the mirror plug takes a lot of effort to pull apart - the pins seem tightly socketed (caveat: it plugs out of view, maybe it's just the casing that is tight?), and even a four-pin molex takes some effort to get apart, while in contrast this pink plug comes apart effortlessly (ok, it has a latching action that helps). I suspect the pin contact is just not very firm in this connector, allowing dust/vibration/oxygen to take their toll on the connections.
How does it come apart? In the end, moving around the other plug and releasing tension on its wires fixed my problem so I dropped the issue with opening up the pink connector, but I'd like to know the secret to pulling it apart if I have to go in there again.
There is one on each side, they both have to be "open" to free the pink part.
The pink part then hinges open, like a latch or release lever, pivoting around the nub protruding through it. Well, you'll see how it works - once you've pulled those black arms out of the way, the pink part moves easily and will release/separate the plug.
What used to be intermittent airbag light is now persistent. My intermittent seat recall is hit or miss.
I'll have to pull the appropriate fuse(s) and get under the seat again to mess with the connectors (cleaning, and contact alignment).
It's the only way GM will give us a permanent fix. Air Bags have been around a long time. There is no reason this can't be fixed.
"It's not complicated "
It only takes 5 or 10 minuets.
