Battery replacement?
Old Jul 4, 2011 | 09:11 AM
tomiboy's Avatar
tomiboy
Default Battery replacement?
I have an 09 with 9500 miles. My battery went dead 2 years ago while sitting for a month in the winter. I then got a battery charger for the winter. A couple of weeks ago the battery went dead after sitting about 5 days. I may have inadvertantly popped the rear hatch open and not noticed or ?. Last night it was dead after sitting just 2 days. I threw the charger on. This morning ...no green light on charger. Does this mean the battery is gone?
Thanks for the help
Old Jul 4, 2011 | 10:47 AM
RicK T's Avatar
RicK T
Very likely yes. These batteries are not designed for deep cycling, discharge/recharge. Once it has happened the battery is never 100% afterward. Some batteries can take more than others but it certainly sounds like yours is done.
Invest in a Battery Tender, battery maintainer, NOT a trickle charger, for times when you know you won't be driving the car more than a week.
Old Jul 4, 2011 | 11:11 AM
tomiboy's Avatar
tomiboy
I have a Battery Tender (I forgot the name). The car did start right up, then the tender showed green. Maybe it needed longer to get a complete charge up? I will have the battery tested
Old Jul 4, 2011 | 11:14 AM
hydbyj's Avatar
hydbyj
i have an 09, it too lost a battery....they are smaller than average batteries to save weight. so i believe their longevity was not the first priority.
jerry
Old Jul 4, 2011 | 11:41 AM
NYC6's Avatar
NYC6
My 06 still has the battery it was born with. Its a NY car and sits at times for a couple weeks in a very cold unheadted garage in the winter without starting or ever having a charger touched to it. The Vette also has a high powered after market sound system with two large amps. The engine lights off everytime I touch the button. A new OEM GM battery will be going in when the old one finally gives out.
Old Jul 5, 2011 | 08:40 AM
craftsman74066's Avatar
craftsman74066
my 07 in okla is also on the orginal battery and never been on a batt.tender
Old Jul 5, 2011 | 09:27 AM
Turbooo2u's Avatar
Turbooo2u
The battery issue for the C6 seems to be a hit-or-miss proposition. My 05' coupe sits outside in the cold during the winter months and lasted almost 6 years. My 07' Z had it's battery replaced after two years and constantly needs charging while it sits INDOORS.
Old Jul 5, 2011 | 07:47 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
06 with the original still going here just fine. I do put it on battery tender if it's going to sit for more than a few days.
Old Jul 5, 2011 | 10:09 PM
saplumr's Avatar
saplumr
I've got a Battery Tender Plus and I can take the car out for a daily drive, put it back in the garage, hook up the tender and it usually stays red unitil the next day. If yours went green right away I would supspect a problem with the tender.
Old Dec 31, 2019 | 12:45 PM
SAS22's Avatar
SAS22
jerry
Yeah it's funny (or not) that as soon as I bought my car I started having starting problems. First thing ya do check your battery right? I had it checked at Oreillys and they say the battery is good. So I start thinking about the alternator and regulator and the guy at OR tests that too. He gives me kind of this (maybe) response. My charging output gauge is reading perfectly the whole time. I finally call our local Vette shop and run it by him. He says it "really" sounds like a bad battery. I bought a new Interstate from Costco and everything has been fine since. I think it was just the draw down of several hours with all the interior lights on.
Old Jan 7, 2020 | 06:37 PM
Sunwarrior's Avatar
Sunwarrior
If you have a advance auto parts store near you, give them a call and see if they have a midtronics electrical system tester. starter alternator and battery all in one test. Pop the tops off the battery and see if there is any water in it. 15vdc is really high the regulator should be about 14.4vdc max. Check the voltage with a volt meter at the battery with the car off, then check it with the car running. Make sure it does not go above 14.4vdc.
Old Jan 7, 2020 | 07:05 PM
SAS22's Avatar
SAS22
Good idea I'll look for a store that has one. The guy at O'Reilly's made a mistake on the battery apparently. I should have asked the Costco guy to check it. The all in one machine sounds great.
Old Feb 16, 2023 | 05:49 PM
Red08's Avatar
Red08
If properly maintained, a battery can last more than 5-6 years. A happy battery is a fully charged battery. That is why I use a battery tender if the car is going to sit more than a week. Its easy to hook up and takes hardly any time.
Old Feb 26, 2023 | 10:12 AM
woodsdesign's Avatar
woodsdesign
[QUOTE=RicK T Invest in a Battery Tender, battery maintainer, NOT a trickle charger, for times when you know you won't be driving the car more than a week.[/QUOTE]
So, what is the difference between a tender and a trickle charger
To Battery replacement?
