what is this noise??
Jul 11, 2011 | 01:43 PM
I went to the track Friday to try out my new tires and I now have a new noise. At the end of every run when I lift I get this " errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrr " noise that sounds like gears. here is a video clip, listen when I finish the race and I slow down. The car does not make the noise on the street and the second I turn off the track the noise is gone. I know all of my fluid levels are good.
Jul 11, 2011 | 11:46 PM
Jul 16, 2011 | 02:49 PM
Jul 16, 2011 | 05:44 PM
You're video clip is just a picture...
Jul 16, 2011 | 06:48 PM
Quote:
Originally Posted by
Hoonose
Try it again because it was a video for me.
Jul 16, 2011 | 07:19 PM
Crowhater
Weird, .jpg is just a picture for me.
Jul 16, 2011 | 08:04 PM
Just a picture for me also.
Jul 16, 2011 | 11:28 PM
Jul 16, 2011 | 11:42 PM
That sounds like an unhappy automatic transmission. Next time knock it into Neutral during coast-down and see if the noise stops.
If so, a fluid change might be worth a shot...if no change then consider having the trans disassembled and beefed-up.
Jul 17, 2011 | 12:01 AM
I drive my car every day and the trans has been acting fine I never hear this noise on the street. I just had an external cooler installed and the fluid looks good. The only thing different about the car is the new toyo tires and black rims.
Jul 17, 2011 | 08:54 AM
Jul 17, 2011 | 09:28 AM
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Changing the tires might just be a coincidence. It does sound like your A6 may be going. I would look into that.
So what were you numbers?
Jul 17, 2011 | 09:34 AM
I sent this thread to a friend of mine that owns a auto trans shop, and is a drag racer. We'll see what he says.
Jul 17, 2011 | 10:46 AM
LTC Z06
He says, "Sounds like the pinion is loose, or its support is gone."
http://www.vetteweb.com/tech/vemp_08.../photo_21.html
LTC Z06
He says, "Sounds like the pinion is loose, or its support is gone." I also thought it was rear end noise when I heard it.
Jul 17, 2011 | 11:03 AM
So how do I find out for sure? The car drives 100% normal, the only time I hear this noise is when I am at the track and finished with my run.
Jul 17, 2011 | 12:03 PM
Crowhater
I would say you only hear it after getting over 100mph at full throttle then lifting the gas. Parts break and wear out when we race. So get to a shop and tear it apart or run it until breaks.
Jul 17, 2011 | 02:55 PM
Like he said, either teardown or run it to failure. I still think the noise is transmission, not differential, but it's impossible to know for certain.
Jul 17, 2011 | 03:00 PM
I had an odd noise around 1800 RPM on deceleration coming from under the hood. It was the A/C compressor going.
Jul 17, 2011 | 03:02 PM
Hoonose
I have the ac off at the track.
