Right rear tire flat!
Old Jul 12, 2011 | 01:31 PM
martinf55's Avatar
martinf55
Default Right rear tire flat!
Start my car today, DIC flashes "RIGHT REAR TIRE FLAT". Damn, I get out to look and it seems fine. Check the air pressure...30.5psi. Perfect. What's going on? After 5 mins. on the road it goes away and the DIC is back to normal. Hasn't happened since.
Old Jul 12, 2011 | 02:12 PM
Harbinz51's Avatar
Harbinz51
Sounds like the battery may be getting weak in the TPM
Old Jul 12, 2011 | 03:02 PM
martinf55's Avatar
martinf55
I guess the way to change the battery is to remove the tire from the wheel?
Old Jul 12, 2011 | 03:04 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Good guess. You knew with GM designing that you're lucky you don't need to drop the tranny too! Actually, I think they can break the bead and get at it without pulling the whole tire off the rim.
Old Jul 12, 2011 | 05:51 PM
Harbinz51's Avatar
Harbinz51
If its a Non run flat tire you should be able to get it out without removal of the tire with ease. A run flat may give you some issue. Factory wheels are much easier than dished aftermarket wheels also. Good Luck
To Right rear tire flat!
