What does your oil pressure usually read in your Vette? Just curious to see what 'standard' is...my new GS seems to read around 60 psi most of the time and right at 80 psi when I first start the car and drive the first mile or so. Is this normal?
My 05 is at 30 psi at idle and about 40-45 when driving.
Did you put too much oil in it from an oil change?
Search this forum I think. I recall not too long ago someone asked the same question and it was normal due to the dry sump in the GS making it higher than a normal coupe, etc.
It is a MN6 GS with dry sump. Sounds like it's normal.
I was wondering the exact same this. My 2011 MN6 GS with 700 miles reads right around 80psi (right at the top end of the scale) for the first few miles on starting then relaxes back to 50-70 after that. So I guess its normal for both you and me OR we both have problems
Frank
ps-checked oil level and its bang on. Factory oil too. Also no warning messages displayed neither........
