Best Method to Pin Crank
Old Jul 19, 2011 | 06:39 PM
TxPres's Avatar
TxPres
Default Best Method to Pin Crank
I have done a lot of searching on how to pin the crank. It appears that there are two different methods used to pin the balancer to the crank.
ATI has a kit that installs the pin in a radial orientation.
A&A has a kit that installs the pin in a horizontal orientation.
There may be other kits out there, but these seem to be the most talked about.
The ATI kit might be a little easier to use because you can drill straight up. Other than that, is there any technical reason to use one over the other?
Old Jul 19, 2011 | 07:37 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I have always used the A&A Pin Kits and no issues. The crank is easy to drill with a good drill bit.
Old Jul 19, 2011 | 08:14 PM
TxPres's Avatar
TxPres
I was doing some more searching and found a couple of times where the pin installed using the ATI method (not necessarly their kit) sheared off. Not sure what caused it to happen.
I probably lean toward the A&A kit.
Old Jul 19, 2011 | 11:12 PM
DSOMC6's Avatar
DSOMC6
With the ATI kit you can pin the crank in two places if you are running a F/I set-up.
To Best Method to Pin Crank
