ls-3 rough idle on start-up
Old Jul 20, 2011 | 09:02 AM
vettephyxer's Avatar
vettephyxer
Default ls-3 rough idle on start-up
A few weeks ago I traded in my 07 coupe for a 2011 coupe. I love the newer car and the ls-3 is awsome except for one thing, rough idle on start-up when cold. Is this normal? Compared to my 07s ls-2 this thing feels like it has a plug wire loose or something,(I checked them). All is good after warm-up and I don't want to make a trip to the dealer if this is normal.
Old Jul 20, 2011 | 09:17 AM
Rob Willis's Avatar
Rob Willis
Do you have the NPP exhaust by chance? Pull the fuse?
When starting my 2011 GS LS3 up with the NPP pulled, it has a rough-idle for 5/10sec.
Old Jul 20, 2011 | 09:56 AM
vettephyxer
I forgot to add, no dual mode exhaust, my car is a base 1-lt mn6.
Old Jul 20, 2011 | 10:38 AM
RicK T's Avatar
RicK T
My '08 LS3 is never rough at start up.
Old Jul 20, 2011 | 11:03 AM
BLKCLOUD's Avatar
BLKCLOUD
My no-option 2010 does the same thing, but only for a few seconds. I wouldn't worry about it.
Old Jul 20, 2011 | 11:11 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
The rough idle is the timing being pulled to heat the cats up. I have modified the spark timing for this feature and smooth start up....everytime.
Old Jul 20, 2011 | 01:42 PM
C7&7's Avatar
C7&7
Yeah I think Brian has it nailed here.
This seems to be normal with the LS3.
Old Jul 20, 2011 | 03:53 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
When we traded our 2006 for a 2009, I noticed that the 2009 LS3 idles rougher sometimes, hot or cold.
Old Jul 20, 2011 | 05:39 PM
JoesC5's Avatar
JoesC5
Normal. My Z06 has a nice "cam lope" when the engine is started cold. Lasts for a minute or two, then smooth as silk 600 RPM. I don't feel it, I just hear it.
Old Jul 22, 2011 | 08:58 AM
vettephyxer
Thanks for all the info folks! I can now enjoy my car even more knowing she's perfectly normal. I have noticed the inside of the exhaust tips stay cleaner longer with the new car so the timing for cats warm-up thing must be right on.
Old Jul 22, 2011 | 12:23 PM
Bowtie_Brigade's Avatar
Bowtie_Brigade
Ditto - Mine does for the first few seconds on start-up. I have the NPP exhaust.
Old Jul 22, 2011 | 12:34 PM
Gearhead Jim
St. Jude Donor '13
If you have the A6 tranny, many/most of the cars also have a slight shudder or vibration for a second or two, when you ease off the gas about 60 mph. This is also "normal", and it sounds great if you have the NPP open.
Old Jul 24, 2011 | 09:25 PM
Purvis's Avatar
Purvis
Normal..
My 2011 Grand sport has the lope for about 3 - 10 seconds when cold. Feels strange, but then evens out.
Old Jul 24, 2011 | 11:17 PM
v8dave's Avatar
v8dave
2nd Gear
Default Normal
Ditto the it's normal comments...
My 2008 M6 always has a "cold" lope at idle for a few seconds rolling out of the shop. By the time I'm down the street at the stop sign it's running smoothly. It reminds me of my 5.0 Mustangs of ~1990--which always had a burble at idle.
Old Jul 25, 2011 | 05:30 PM
Corvette V's Avatar
Corvette V
Default Why?
Because on a cold start up your computer is in open loop mode until it reaches target temps/values, then it goes into closed loop mode using primarily the o2 sensors to adjust fuel delivery and timing for minimum emissions, optimum gas mileage and power.
Old Jul 26, 2011 | 06:31 PM
Kerrdogg's Avatar
Kerrdogg
My 11 GS 1lt does it too, maybe it due to the lack of amp draw on the alternator.
Old Jul 27, 2011 | 07:31 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Nope, if you zero out the cat lightoff spark table........the roughness is completely eliminated. Hot starts, cold starts.....makes no difference.
To ls-3 rough idle on start-up
