08 LS3 Stock Dyno
Old Jul 25, 2011 | 09:54 PM
TripleAstyle123's Avatar
TripleAstyle123
Default 08 LS3 Stock Dyno
I just had my Stock 2008 JSB Z-51 MN6 Dyno'ed on Friday at The Car Craft nationals. NPP open/M2W switch 381HP 362TQ 32% humidity and 98F I guessed from reading other stock LS3 times about 380-385 so I am happy with the results. It was a Dynojet Dyno.
Old Jul 25, 2011 | 09:56 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Looks right in line with what it should be doing.
So when do the mods start?
Old Jul 25, 2011 | 10:52 PM
thatonedude1's Avatar
thatonedude1
Default Corrected??
I presume that 381 is corrected to std day. Either way, very nice number under those hot conditions? You were probably losing a bit of timing due to the extreme heat.
Old Jul 26, 2011 | 08:34 AM
FloydSummerOf68
I usually assume that dyno numbers posted are SAE corrected and not STD.
Old Jul 26, 2011 | 06:53 PM
Boomer111's Avatar
Boomer111
Torque seems a tad low.
Old Jul 26, 2011 | 07:42 PM
TripleAstyle123
They are SAE. I know the coolant temp was 203F, so it wouldn't have pulled timing for that, but at 98F the entering air temp may have been higher, not sure what temp it takes to pull timing if thats even possible.
Only mods will be over the next summer or two, LT headers or Z06 manifolds, new non-RF tires, and a tune.
To 08 LS3 Stock Dyno
