LS2 Engine Block Coolant plug ???
Old Jul 30, 2011 | 02:13 PM
SkyKing421's Avatar
SkyKing421
Default LS2 Engine Block Coolant plug ???
It's time to change the Dexcool on my '07 LS2.
I usually drain the radiator and the engine block (3 drains on older blocks).
Engine blocks have always had drain plugs near the middle of the block next to the pan, but maybe the LS2's don't have one.
I guess one would be a little higher up near where the center of the crankshaft is, but I don't see one.
I pulled out a small 10mm bolt and there was oil in there. Not that one!
My service books don't list a torque spec for a drain plug on the LS2, but it does for an LS7.
Anybody know if there are block drain plugs for the '07 LS2?
Old Jul 30, 2011 | 06:16 PM
torquetube's Avatar
torquetube
The left drain is under the header near the front of the block. It's a giant brass plug with a 17mm internal hex drive. You can't miss it.
The right drain is directly above the starter motor near the back of the block. You have to remove the starter to get at it. The right drain plug takes a conventional socket.
If you don't already have a 17mm Allen wrench for the left drain, Mac Tools P/N SC80 is pretty handy. It's a very compact, one-piece special-application socket, 3/8" drive on one end (1/2" would have been better) and a stubby 17mm on the other.
Old Jul 30, 2011 | 06:25 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Just flush it a couple of times after draining the radiator. See the following: http://forums.corvetteforum.com/1577363773-post15.html
Old Jul 30, 2011 | 07:25 PM
torquetube's Avatar
torquetube
Everybody jumps through hoops to avoid pulling the starter, but it's no big deal. I think the OP is on the right track by completely draining the block.
Old Jul 31, 2011 | 01:46 PM
SkyKing421's Avatar
SkyKing421
I drained 1 1/2 gallons from the radiator drain, so that is enough for a refill of coolant after a flushing.
Thanks for the advice about the block drains, but I'll do the flush method rather that buy the allen wrench and mess with the large plugs in an aluminum block. Don't want to disconnect the power to remove the starter either, since I would lose the memory. It runs good now, but wasn't as good when new.
I'll even use distilled water (it's cheap) and run the heater to get most of it flushed.
I had a disappointing experience with a '64 fuelie I restored. The new engine ran perfectly and never needed any coolant added. After 3 or 4 years the coolant was all rusty. Darnit, hard way to learn that the rust inhibitor gets used up.
At least Dexcool lasts longer.
Old Jul 31, 2011 | 02:27 PM
torquetube's Avatar
torquetube
Don't bother running the heater. There is no heater valve.
Old Aug 2, 2011 | 05:11 PM
SkyKing421's Avatar
SkyKing421
No heater valve anymore. Good info. Will save me from running it in this 100 degree heat!
Thanks much.
To LS2 Engine Block Coolant plug ???
