So the other day, I parked my 2010 Grand Sport outside, rolled windows down and have had it in garage to work on it several days, disconnecting and reconnecting battery several times, now today I went to roll windows up and the passenger works fine, but the drivers does not go up or down. Its in down position, but when I hit switch, I hear it click, so not sure if it has to be reprogrammed or what.
Anyway, anytime the battery is disconnected or goes dead you need to re-index the windows when the battery is fixed. The doors have to closed to do so. Here's the procedure if you need it.
Get in, close the doors
Start the car or turn on ignition
Raise the windows all the way up and HOLD the switches up for 3 seconds and release.
Hold the switches up again for 3 seconds and release.
Done
