California Mods
Old Jul 31, 2011 | 01:07 AM
erik_26's Avatar
erik_26
Default California Mods
Still new to Corvette.
What are some good low budget mods, that will yield moderate to high HP & Torque returns, that are still Ca legal and will pass smog.
In other words, best bang for the buck.
I am not looking for the fastest 1/4 mile. But I know there is a lot more then just the stock 400hp the car comes with. That LS2 sounds like it is begging to be unlocked.
It's not a daily driver but I would like to retain its reliability.
Any suggestions?
Old Jul 31, 2011 | 01:33 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Any suggestions?
Move to another state?
If you want to stay legal, you need CARB numbers on everything. A CARB legal supercharger is probably the way to go.
San
Old Jul 31, 2011 | 05:55 AM
The running man's Avatar
The running man
I have to agree with oldmansan. If you want to stay completely smog legal your only options are a CARB legal supercharger and either a cat back or axle back exhaust system. I've even heard of guy's failing the visual portion of the smog test because of an aftermarket air induction system. CARB has gotten way out of hand and needs to be stopped. www.killcarb.org
Old Jul 31, 2011 | 06:15 AM
boraxman's Avatar
boraxman
My plans down the road are CARB approved supercharger full ZO6 exhaust.
Old Jul 31, 2011 | 07:42 AM
Gering's Avatar
Gering
Tolero Apto Victum
Thanks for the link!
Old Jul 31, 2011 | 09:33 AM
Kenny94945's Avatar
Kenny94945
Camshaft w/ Cat back exhaust.
or
CARB Supercharger.
Any intake (without CARB sticker) will fail the visual inspection. There are no CARB headers yet some recommend Z06 exhaust manifolds.
Some computer tunes will increase performance and still pass smog.
Ask Rick at Synergy Motorsports in Fremont.
Old Jul 31, 2011 | 10:40 AM
Boomer111's Avatar
Boomer111
I picked up around 40 rwhp with Z06 manifolds/cats and "H" pipe with tune on a LS3.
Numbers were adjusted due to the change in gears. Actually rwhp with 4:10's and stated mods was 403. Stock was 375 rwhp. Most say 10 rwhp loss due to 4:10's. I came up with closer to 12 rwhp. I figure my number is 415 rwhp with the gears but adjusted to read without gear change.
While not a totally legal change I suspect no problems passing visual inspection. The Z06 gear is OEM just not specific to the LS3. Looks stock to me.
Stock air intake too.
Old Jul 31, 2011 | 04:20 PM
WHYASK's Avatar
WHYASK
Actualy there are CARB legal headers :-) JBA makes a set ! Personally go with te full ZO6 manifold cutback setup - then a carb legal intake of some sort - mild street cam and a
Good tune and your in like sin . I posted this same question about 3 weeks ago when I picked up my baby in sacramento
Old Jul 31, 2011 | 05:44 PM
djbrun's Avatar
djbrun
+1 On the full Z06 set up, mild cam an a tune.
DJ
Old Jul 31, 2011 | 06:55 PM
Ragtop 99's Avatar
Ragtop 99
won't help with dyno numbers, but gears and tires (M6) or a torque converter and tires (A6) will go a long way to improving off the line performance and the fun factor w/o needing a carb sticker.
Old Jul 31, 2011 | 09:02 PM
WHYASK's Avatar
WHYASK
Whats the average price running in Cali for gears installed ...? I only ask cause a cam setup with a tune might be just as much ....
Old Jul 31, 2011 | 11:19 PM
C6topless's Avatar
C6topless
Cat back -- themostat -- air intake .. tune..
Old Jul 31, 2011 | 11:29 PM
Jim_H's Avatar
Jim_H
around the same as a cam install 2000 or so.
Old Aug 1, 2011 | 04:07 AM
WHYASK's Avatar
WHYASK
Yeh in that case just get cams and tune Or exterior mods and save for an Eforce setup or procharger
Old Aug 1, 2011 | 10:57 AM
Boomer111's Avatar
Boomer111
Only problem with cam is additional valve train wear/maintenance.
I guess if you go small enough it would be ok, but you could get the same power from bolt on mods without having to open the engine up and still pass emissions going with the Z06 set up/tune.
Most power and legal is the FI route but then it is $$ and engine longevity is questioned.
I went with the Z06 system/tune and 4:10 gears. You could get it done for around $3500.
Old Aug 2, 2011 | 04:30 AM
WHYASK's Avatar
WHYASK
I keep reading about this issue... As comming from the mustang world and the NSR setups (No springs required) Im not certain i grasp this concept completely.. wouldnt a mild cam and good tune elminate the valve train wear ..?? As for gears what are the stock M6 equipped with anyway...?? I assume with 6 speeds 4.10s will be just fine anyway street and freeway.. also with a cam in the LS engines, is it needed to run a higher gear ratio to offset the loss of low end trq..???
Old Aug 2, 2011 | 12:23 PM
JoesC5's Avatar
JoesC5
All C6's, including the Z06 & ZR1, with a manual transmission have 3.42 rear gears. Your 4.10 is aftermarket, not OEM from a Z06. The ring gear is larger in diameter, for additional stength, in the Z06 but the ratio is the same....3.42...as a base C6 LS3.
To California Mods
Old Aug 2, 2011 | 01:21 PM
petermj's Avatar
petermj
Any suggestions?
upgrade to LS3, LS7 or LS9 equipped vette
Old Aug 3, 2011 | 06:01 PM
Boomer111's Avatar
Boomer111
Usually the performance cam will require more lift hence tougher on the springs. Although wanting a smog legal upgraded cam would not be as tough on the springs. Still though upgraded springs are recommended.
Old Aug 3, 2011 | 06:46 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
and a VMax ported TB
