Corsa Exhaust ??
Old Aug 7, 2011 | 10:33 AM
naccar's Avatar
naccar
Default Corsa Exhaust ??
Just installed corsa xtreme on my 05 with auto trans. When it hits second gear under hard acceleration it makes a weird sound can anyone exlpain this?
Old Aug 7, 2011 | 12:46 PM
saplumr's Avatar
saplumr
Well...a "weird" sound is not very definitive. You might want to help us help you.
Old Aug 7, 2011 | 12:53 PM
naccar's Avatar
naccar
it almost sounds like crackling for a second.
Old Aug 7, 2011 | 01:03 PM
saplumr's Avatar
saplumr
Crackling or rattle? If it's a rattle you may need to adjust the support/mounting springs in the center tunnel. Crackle I have no idea.
Old Aug 7, 2011 | 04:33 PM
naccar's Avatar
naccar
it sounds like it is coming from the mufflers,I thought it might just be change in exhaust flow for that second.
Old Aug 7, 2011 | 05:30 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
After you've put the new exhaust system through a couple heat/cool cycles, re-torque (49 ft/lbs) all the clamps.
Don't know if this will affect what you're hearing, but Corsa recommends it be done.
Maybe a slight leak is making the noise?
Good Luck
Old Aug 7, 2011 | 05:51 PM
naccar's Avatar
naccar
re-torqued all the bolts,still making that sound. Could it be sudden change in back pressure?
To Corsa Exhaust ??
