long 5th gear
Old Aug 9, 2011 | 09:50 AM
Randy_medion's Avatar
Randy_medion
Default long 5th gear
Hi, I tried to top out my '07 LS2 C6 a6 (2.56) and I did 170mph in 4th before it shifted into 5th, and after that it became slow with accelerating, I think the top speed suppose be around 186mph but it would take forever to get there ( 5100rpm@ 186) and at that rpm range it would only put down about 310hp at the wheels, so I think you would never reach the peak hp of the engine (6.000rpm) so I don't think it will ever reach 186mph, am I right?
Old Aug 9, 2011 | 10:37 AM
LEAVINU's Avatar
LEAVINU
Stock..... it'll get there eventually.
Old Aug 9, 2011 | 11:12 AM
Randy_medion
ok if you say so....but soon I'll get a Vararam intake and cut outs, will that make any sweet difference???
Old Aug 9, 2011 | 01:18 PM
sallen619's Avatar
sallen619
I believe the 186 mph was done in a manual Z51 car. The 5th gear and diff ratio is different than you car.
Old Aug 9, 2011 | 01:25 PM
Ragtop 99's Avatar
Ragtop 99
It will help, but you need a lot more than that to make a noticeable difference. Add a ported intake/FAST 90, headers, and a tune with the Vararam and it will get you there sooner.
The other option would be to look at a gear swap. Around a 2.95 would be pretty ideal; even 2.73s would help.
Old Aug 9, 2011 | 02:11 PM
el es tu's Avatar
el es tu
I have an '07 a6 as well, and have gotten it somewhere around 180mph (stopped looking down past 175) before I slowed it down
I agree - past 170 you kind of have to push it.
Minimal mods to get it around 400 rwhp and new rear end gear (3.42) should bring you into the mid 3 sec zone for acceleration and closer to a 200 mph top speed...
Old Aug 9, 2011 | 02:45 PM
Ragtop 99's Avatar
Ragtop 99
3.42s don't do as much as I would have expected. Using a gear calculator, here is a comparison of mph at 5250 rpm:
2.56...193 mph
2.73...181 mph
2.93...168 mph (192 mph @ 6000 rpm)
3.15...157 mph (186 mph @ 6250 rpm)
3.42...183 mph (6th)
3.15s would be pretty ideal if there was no converter slip or if you run a little larger tire.
Old Aug 9, 2011 | 06:57 PM
JoesC5's Avatar
JoesC5
Just take a ham sandwich to snack on while you are waiting to hit 186 MPH.
Old Aug 9, 2011 | 08:36 PM
TMyers's Avatar
TMyers
When making a high speed run in the A6 take 4th right to redline, it looks like you did. If you don't it is a very long climb in 5th.
Old Aug 10, 2011 | 10:30 AM
Randy_medion
I did redline it but some vids on youtube make the LS3 look much faster in 5th, or that would be 2.73 instead of 2.56?
Old Aug 10, 2011 | 01:28 PM
Randy_medion
does anyone know wich automatic equipped C6
has a higher top speed, 2.56 or 2.73??
Old Aug 10, 2011 | 02:30 PM
TMyers's Avatar
TMyers
Randy mine had the 2.56 rear gear. I made it to 172 before I ran out of runway. The car was still pulling when I had to get on the brakes. This was with a 06. Given enough space I am sure it will go faster.
Old Aug 10, 2011 | 04:17 PM
Ragtop 99's Avatar
Ragtop 99
The faster you go, the more HP needed and its an exponential growth of HP needed. A 2.73 car will be making more HP than a 2.56 car in 5th gear at 180 mph because the motor is going to be 6% higher in the rpm band and thus making a few more HP. The problem is that at 180 mph, you need a lot more then just a few extra HP to accelerate noticeably faster.
At the speeds you are looking at, the 2.73 car might get to another 2 mph faster just because of space needs. If you had unlimited space, I'd guess the difference drops to about a 1 mph, if that.
To long 5th gear
