How important is dyno tune?
Old Aug 9, 2011 | 10:26 AM
Jimmy C-6's Avatar
Jimmy C-6
St. Jude Donor '12-'13
Default How important is dyno tune?
I bought my first Vette this year, an 05 coupe, and it came with Corsa exhaust. My son and his friends tell me I need to take it to Livernois Motor Sports for a Halltech and a dyno tune. How important is the tune? It's not that I'm cheap, but if the difference is negligible,,, but if it makes a difference in reliability I'll go for it.
Old Aug 9, 2011 | 10:30 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
A dyno is only a tool for tuning purposes when you mod your car. If all you did was bolt on mufflers, you r car is essentially stock and there is no need to dyno your car. You can tune it without putting it on the dyno for now. If you add a lot of bolt-ons, that is a different story. The installer may want to dyno tune it.
Old Aug 9, 2011 | 10:32 AM
Jimmy C-6's Avatar
Jimmy C-6
He said they want the car for 2 days to check the settings.
Old Aug 9, 2011 | 10:43 AM
Jimmy C-6's Avatar
Jimmy C-6
I just ran the numbers and they only charge $369 for the install and dyno tune, sound cheap to me, so I guess I'll go for it.
Old Aug 9, 2011 | 10:59 AM
LEAVINU's Avatar
LEAVINU
....... Tuning only takes a few of hrs at best for a well modified car. For a basically stock car it's a piece of cake to get everything tuned in an hour or so.
Old Aug 9, 2011 | 11:38 AM
Jimmy C-6's Avatar
Jimmy C-6
Sounds like they want to let it sit and work on it in their spare time.
Old Aug 9, 2011 | 01:16 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Tuning makes a HUGE difference, even on stock cars.
It'll be the best 370 bucks you've ever spent.
Old Aug 9, 2011 | 07:45 PM
Swiftrider08's Avatar
Swiftrider08
Glad to see you are actually taking your car to the tuner. I have been through the mail order tune ordeal and in the end, the car may seem to run fine, but I have no clue what the tuner did or what you ended up with. I don't like that at all.
Old Aug 9, 2011 | 08:26 PM
Larry R. Quinn's Avatar
Larry R. Quinn
They may want to keep it for two days so they can do a " cold start " and check the start up tune parameters . On a mostly stock car , such as yours , there should not be any problems . I doubt that you will regret getting the tune after the Halltech install .
Old Aug 9, 2011 | 08:42 PM
WHYASK's Avatar
WHYASK
Unless you have alot of bolt ons dont waste your money when the car is stock. get the mods done first then have a baseline done then have the mods installed then get a good tune to compliment the mods.
Old Aug 9, 2011 | 09:53 PM
Livernois Motorsports's Avatar
0Livernois Motorsports
Supporting Tuner
while some shops may well do this type of work, we never just slap a tune in a car and thrash it on the dyno in a short amount of time. We spend the time to properly calibrate all aspects of driving the car, WOT, part throttle, idle, cold start, etc. This is something, while technically being able to be done in a few hours time, is best to be validated over the course of a day. Also, scheduling the additional time allows us to make certain there are no other issues. Things like having a bad tank of fuel, or needing a set of spark plugs are unfortunately common enough that we plan for them, rather then promise a short time and then have them create scheduling conflicts with the plans that were made based off of the minimum required amount of time for the work.
Old Aug 10, 2011 | 09:11 AM
LEAVINU's Avatar
LEAVINU
I posted my comment prior to realizing the tuning would be done by you guys. With that being said, I've seen you guys work and realize you are much more detailed than most therefore requiring more time. All of the points you made above definitely justify the overnight stay.
Old Aug 10, 2011 | 09:20 AM
Jimmy C-6's Avatar
Jimmy C-6
I guess thats why my son and his friends said Livernois is the place in metro Detroit. Can't wait to have you guys help me. Now I just have to get my wife to give me a ride back. Maybe a piece of jewelry would help? )))
Old Aug 10, 2011 | 10:30 AM
taken19's Avatar
taken19
Track Junky
Bribery works like a charm... I had to cough up an iPad for my Heads/cam install.
Old Aug 11, 2011 | 10:08 AM
LKicklight's Avatar
LKicklight
Default Warranty
Will Dyno Tuning a stock engine invalidate the factory warranty?
Old Aug 11, 2011 | 10:10 AM
FloydSummerOf68
Only the powertrain warranty. The rest of the factory warranty will be in place.
Old Aug 11, 2011 | 10:24 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
Any performance tune will void the powertrain warranty.
To How important is dyno tune?
Old Aug 11, 2011 | 10:27 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
Gold is expensive these days. Depending on her taste, it may be cheaper to give her the Vette and buy another one!!
Old Aug 11, 2011 | 10:28 PM
TripleAstyle123's Avatar
TripleAstyle123
Old Aug 11, 2011 | 10:30 PM
TripleAstyle123
Makes total sense from a customer service and quality point of view IMO.
