Bought a Headlight that needs work - Help Please!
Old Aug 11, 2011 | 08:11 PM
LegendSS28's Avatar
LegendSS28
Default Bought a Headlight that needs work - Help Please!
Hi All,
I bought a Black headlight for my 08 C6 on Ebay for a very cheap price. There are some issues with the headlight, but for the price I figured what the heck, may as well give it a try. Anyways, heres the issues...
1) On the underside of the headlight the tabs that hold the screws/bolt in are broken off with the bolts. In other words, the plastic broke, so I need to either re-weld the plastic back on, or possibly glue it somehow? Any advice here?
2) The lens has two pretty large scratches. I have read a bit about wetsanding them, but not sure if this would be possible. Anybody have experience wetsanding a lens? The scratches are fairly deep, and it seems one has actually been filled with some sort of material.
Thanks guys, let me know what you think!
Old Aug 11, 2011 | 08:24 PM
RicK T's Avatar
RicK T
Contact member RLSebring for help, he specializes in headlight work.
Here's a recent thread where he posted (#2) so you can get to his contact info:
http://forums.corvetteforum.com/c6-c...n-c6-help.html
Old Aug 11, 2011 | 10:12 PM
m R g S r's Avatar
m R g S r
What do you mean "a" headlight? You only bought one to swap out for your colored headlight? You can just paint the bezels of the headlight....
http://forums.corvetteforum.com/c6-c...eadlights.html
It wasn't fun separating the lens from the housing then removing the glue...and that was no where near the first headlight I ever separated!
Old Aug 11, 2011 | 11:32 PM
DSOMC6's Avatar
DSOMC6
Originally Posted by LegendSS28
Hi All,
1.Two part, quick setting epoxy. Follow directions (let it completely cure for 24hrs before you touch it.
2.You can purchase a new lens and go through the baking process listed in the above link. Or, you can purchase a headlight lens repair/restore kit and try to get the scratches out. The Wallmart, believe it or not, by my house has a kit that works pretty good.
Old Aug 12, 2011 | 12:03 AM
m R g S r's Avatar
m R g S r
Wetsanding does work by the way (400.600.800.1000.2000.buff with heavy cut compound and good high speed buffer) but it's a lot of work and a long process. Depending on how deep the scratches are, you may start with a finer paper.
Old Aug 12, 2011 | 12:21 AM
LegendSS28's Avatar
LegendSS28
Haha yes, I bought just a single headlight, however I don't plan to run the car with mismatching ones. I paid 40 bucks for the headlight so I figured I may as well scoop it up and see if I can make it work, and I will wait out until I find a nice deal on a left headlight. I am not in a rush, and don't mind a project as long as I'm confident I can get it nice looking. Thanks for the help guys, I ordered the 3M lens repair/restore kit so I will start with that and see where I get. As far as the broken plastic, do you think something like this would work?
http://www.loctiteproducts.com/p/epx...tic-Bonder.htm
Old Aug 12, 2011 | 02:02 AM
DSOMC6's Avatar
DSOMC6
Not unless you wnat to try and hold the broken piece perfectly still for 30mins.
The epoxy I use hardens in less than a minute and completely cures in 24hrs. You can find it Kragen/Oriely.
Old Aug 12, 2011 | 03:50 PM
LegendSS28's Avatar
LegendSS28
Okay sounds good. I went to Orielly's Auto Parts and picked up some plastic epoxy that says it hardens in 15 minutes. Hopefully itll be quicker and I won't have to hold it there that long, but if I do, oh well. There are just three tabs so it should be too bad.
Old Aug 12, 2011 | 06:10 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
rick gave you the best advice to talk with someone who has done many and experimented. but you can experiment, too.
may want to look at this thread: http://forums.corvetteforum.com/c6-c...d-to-know.html
and another one: http://forums.corvetteforum.com/c6-c...placement.html
Old Aug 12, 2011 | 06:58 PM
LegendSS28's Avatar
LegendSS28
Thanks, I sent him a PM so hopefully I'll hear back. In the meantime, I used the plastic epoxy with what seem to be good results. It has been drying for about 2 hours now, and says will be fully hardened after 24 hours, but so far feels real sturdy. Are there any tutorials on removing/installing headlights? Thanks
Old Aug 12, 2011 | 07:04 PM
RicK T's Avatar
RicK T
I've never seen anyone post a detailed tutorial with pics but here are a couple word descriptions and tips:
http://forums.corvetteforum.com/c6-c...-question.html
http://forums.corvetteforum.com/1576999104-post4.html
Old Aug 12, 2011 | 07:07 PM
RicK T's Avatar
RicK T
And in case you've never been in there, here are some pics from Talon90 to give you some idea what you'll see:
Just be prepared. In order to remedy this they will need to remove or at least loosen your fenders and your front fascia to get at these gaskets.
Old Aug 12, 2011 | 11:53 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
PM sent. Here's a PDF of how to do a front wide body. Use the first part of the steps to get to the lights. You only have to loosen up enough of the top screws in the fenders and front bumper to comfortably get the lights out without scratching something.
File Type: pdf
Old Aug 13, 2011 | 12:14 AM
DSOMC6's Avatar
DSOMC6
Hint: when you epoxy plastic, don't move the adheared pieces until fully cured or you will break the bond. Then you will cuss and swear and have to start all over again.
To Bought a Headlight that needs work - Help Please!
