Where is the G Meter Sensor Located
Old Aug 15, 2011 | 09:18 PM
kurwette's Avatar
kurwette
7th Gear
Default Where is the G Meter Sensor Located
I just had some work done to my C6. The front end was taken off, now the meter is reading all readings to the left side of the display.
Does any one know where the sensor is located?
Thanks.
Old Aug 15, 2011 | 09:25 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Thanks.
Directly behind the ashtray.
Old Aug 15, 2011 | 11:47 PM
Bill Dearborn's Avatar
Bill Dearborn
Be careful the lateral G sensor and the yaw sensor are packaged together in the same module. If you don't have any issues with your ABS, Traction Control or Active Handling don't move it unless you know for sure that is what is causing the problem.
Bill
Old Aug 16, 2011 | 09:31 PM
kurwette's Avatar
kurwette
7th Gear
Would I have to remove the console?
Old Aug 16, 2011 | 09:32 PM
kurwette's Avatar
kurwette
7th Gear
Bill
Thanks for the heads up.
Old Aug 16, 2011 | 11:57 PM
'VETTE PHASE
Yes, you'll have to remove the console and the radio surround. It is mounted just behind the air bag module.
Old Aug 17, 2011 | 08:33 AM
kurwette's Avatar
kurwette
7th Gear
Much appreciated, the picture helps a ton.
To Where is the G Meter Sensor Located
