Help with mod suggestions under 1k
Old Aug 17, 2011 | 04:18 PM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
Default Help with mod suggestions under 1k
Alight forum friends... I am about to make my next purchase however, I am totally torn on what to do. I am thinking about the following.
Options 1)
Headers - Any set and it really doesnt matter. 1 7/8 for sure however, this would pretty much be the end of my mod list. With the my E85 I'm hoping for 25-30whp gain
Headers Price $700 - $1,200
Option 2)
Spiral ported throttle body + Z06 manifold setup + deleting cats
I feel I'm getting more for my money here and I'm leaning more towards this direction.
Throttle body Price $150-$200
Z06 Exhaust price $350 - $450
Total: $500-$750
All that being said which one would net more power and in your personal opinion and, which direction would you go? I'm sure the power would be close if comparing the two although, headers have such a unique sound to them.
HELP! Thanks for your input!
Old Aug 17, 2011 | 04:50 PM
Tikiman12's Avatar
Tikiman12
headers are going to give you the most power
Old Aug 17, 2011 | 05:11 PM
Cromagnum's Avatar
Cromagnum
I think you'll be a lot more happy with headers for the power increase and the noticeably improved sound quality of your exhaust.
Old Aug 17, 2011 | 10:43 PM
Gering's Avatar
Gering
Tolero Apto Victum
There was a big difference in sound when I added my kooks headers.
Old Aug 17, 2011 | 11:06 PM
bdanyluk's Avatar
bdanyluk
Headers....then tires.....then sway bars.....whenever you get the money.....COMPLETELY new feel for the car. Unless you start racing/HPDEs you won't need any more than that if you're on a tight budget....guaranteed.
Old Aug 18, 2011 | 08:31 AM
FloydSummerOf68's Avatar
FloydSummerOf68
OBX headers..best "under $1000" mod that exists for our cars.
If it were an LS2 it would probably be between those or a Ported FAST intake, but the LS3 intake is already very good.
Old Aug 18, 2011 | 08:35 AM
LT1_E85_Corvette
Thanks for all the suggestions everyone! It seems people are leaning towards headers (kinda surprised). Glad I asked and I will be looking in this direction moving forward.
With the price of of the OBX headers I might still have room for the ported throttle body. Gotta love the chase for a good deal!
Old Aug 18, 2011 | 09:54 PM
TripleAstyle123's Avatar
TripleAstyle123
With headers alone doesn't your injector cylcing rate worry you? I would assume if you plan for these mods you will be installing larger injectors?
But I would say headers considering the sound factor alone!
Old Aug 19, 2011 | 08:21 AM
FloydSummerOf68
Good point!
I didn't think about you still being on stock injectors.
Plan on upgrading to FAST 60# or something similar at the same time. They're pretty cheap...only ~370 through Hinson.
Old Aug 19, 2011 | 12:05 PM
LT1_E85_Corvette
Good point!
I have contacted my tuner and I'm only at a 90% duty cycle under WOT. I have lots of room before I have any injector issues. He told me that I should be good to about 500rwhp. Headers and a few other bolt ons should keep me in the clear
Old Aug 19, 2011 | 12:12 PM
FloydSummerOf68
Um...you don't want to take injectors to 100% duty cycle.
You're already really pushing it at 90%.
80-85% is where most like to keep it.
Old Aug 19, 2011 | 12:33 PM
LT1_E85_Corvette
I should be floating around 93-95 only at WOT. I'm already over 85 now with no ill effects. If a injector fails I will either get a larger set or fix the failed injector(s) and put it back on pump gas.
I will donate my car for a experiment
As always I will share the results with everyone
Old Aug 19, 2011 | 12:39 PM
FloydSummerOf68
95% duty cycle when you tune it...changes in weather could very easily cause you to go into a lean condition at WOT, which would be bad.
It's much cheaper to get a set of injectors now rather than what could happen after going lean.
A tuner should not be advising you to get so close to 100% duty cycle.
Old Aug 19, 2011 | 01:24 PM
LT1_E85_Corvette
I will speak with him and see his thoughts. He just said I was at 90% and I'm just assuming I can go higher. Let me ask a few questions and we can pick up this topic later
Old Aug 19, 2011 | 01:30 PM
FloydSummerOf68
It never hurts to have more fueling capability than you need...it does hurt to not have enough though.
Old Aug 22, 2011 | 06:50 PM
TripleAstyle123
Hey Floyd! How hard are injectors to install yourself? I am technically advanced but in a mechanical field other than cars/engines. I have heard from an "iffy" source it is very easy. If I dont have to tear too much apart I would consider doing them to be safe when running my LS3 with E-85. Any thoughts?
Old Aug 22, 2011 | 06:51 PM
TripleAstyle123
running lean at WOT can cause a big boom. not good
To Help with mod suggestions under 1k
Old Aug 22, 2011 | 07:08 PM
seevi's Avatar
seevi
You can save yourself a bunch of money by buying a used, complete ZO6 exhaust system. You can get one very cheap and it's a bolt on! Any mod that impacts the engines breathing will require a tune to get the most out of it.
Old Aug 22, 2011 | 07:14 PM
TripleAstyle123
I talked to a guy this weekend at a corvette only show in MN (stillwater) that said he sold his stock Z exhaust for $400. I think $700 or so is more usual though.
Old Aug 23, 2011 | 09:45 AM
FloydSummerOf68
Injectors are a VERY easy swap with nothing but basic hand tools and an hour or so of your time.
400 is a typical price for manifolds, cats and h-pipe.
If it includes the mufflers that's a great price.
