C6 Differential Chatter
Old Aug 18, 2011 | 04:12 PM
GM Kid's Avatar
GM Kid
Default C6 Differential Chatter
I'm currently Vette-less, but a co-worker has a 2008 and was telling me today at lunch that she hears a weird noise when making tight, slow-speed turns. She took me for a drive and I heard it: Sounds like the very same chatter I used to hear from the differential in my old '01 Coupe. I remember that I got an additive from the dealer, crawled under the back-end of the car and poured it into the drain plug. No more chatter.
Do you think it's the same thing on my friend's C6? I got down and looked for the drain plug, but an aluminum crossmember was in the way and I couldn't see it. If this is the same problem I had years ago, with the same fix, how hard is it to get at the drain plug?
Old Aug 18, 2011 | 04:19 PM
RicK T's Avatar
RicK T
Probably needs the new fluid. GM changed to a newer fluid late in '08 that doesn't require a separate friction modifier additive.
Here's the TSB:
http://forums.corvetteforum.com/1564283516-post6.html
And here's a DIY on changing, it's doable but takes a little finesse.
http://forums.corvetteforum.com/c6-c...s-for-faq.html
Old Aug 18, 2011 | 04:57 PM
GM Kid's Avatar
GM Kid
Thanks, Rick! Perfect info. Any idea what dealerships charge to take care of this TSB?
Old Aug 18, 2011 | 05:24 PM
RicK T's Avatar
RicK T
I don't off hand. I'll look around and see if I can find any references. If I do I'll post back with an Edit in this post.
Edit: Ah, found it in a current discussion. See post #15:
http://forums.corvetteforum.com/c6-c...ing-noise.html
Old Aug 18, 2011 | 07:47 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Here's the TSB:
As usual, Rick is correct.
Be sure to note the part about not needing any additional additive.
Just pour in the new stuff and go do a few figure-8's in the parking lot.
Old Aug 18, 2011 | 08:11 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
or opt for the 75/90 severe duty Amsoil
Old Aug 18, 2011 | 10:15 PM
VetteTrpr's Avatar
VetteTrpr
I had the same issue and after researching all the great info here, I just finished changing my differential fluid with Royal Pruple Extreme Gear 75W90. It was easy and worked like a charm..
Old Aug 19, 2011 | 09:19 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
If it's an 08, it should be covered under 5 YR/100K powertrain warranty. I would have her check with the dealer first.
__________________
Old Aug 19, 2011 | 01:15 PM
GOLD72's Avatar
GOLD72
The new fluid DEXRON LS didn't become factory fill in corvettes until MY2009. Meaning 2008 and older vettes are very susceptive to diff clutch chatter. An alternate to the DEXRON LS is AMSOIL Severe Gear 75W90 which I have used in three separate model year vettes (06, 07,08) with total success stopping this chatter.
Old Aug 20, 2011 | 12:08 PM
MurphMan2's Avatar
MurphMan2
I just had it done on my '08 yesterday. I had 3 days left on the 36 month bumper to bumper. Service adviser told me that it would be covered if I did it before the expiration and not after that. I told him that I recently purchased the GMPP Gold, and he said it still wouldn't be covered and would be like an engine oil change.
It really made a huge difference as it's nice and quiet now.
Old Aug 20, 2011 | 04:39 PM
CroOrange's Avatar
CroOrange
Normally the first change done for chatter issue on an 08 is paid by GM. Had mine changed, chatter gone.
Old Aug 22, 2011 | 02:50 AM
HC Mechanic's Avatar
HC Mechanic
Probably just needs a good breaking in...maybe take it out for some on/off ramp adventures for her
Old Aug 22, 2011 | 08:30 AM
REVAK's Avatar
REVAK
Here's the TSB:
Yup, GM part # 88862624 , dexron LS 75W-90 gear oil, use NO friction modifiers.
Old Aug 22, 2011 | 04:50 PM
TXAtomic's Avatar
TXAtomic
I also had this issue on my 08 and finally had it looked at right before the 36K mark came up. Dealer installed new fluid and did a couple of figure-eights to mix it and good as new; all under warranty.
To C6 Differential Chatter
