416 stroker
Old Aug 18, 2011 | 05:31 PM
dennis50nj's Avatar
dennis50nj
Default 416 stroker
so many stroker threads lately... i have been waiting for the dyno numbers so i could post in them, but i decided to just start a new thread.
Cartek built it, 416 stroker 587 rwhp 518 rwtq on pump gas, no meth, cant wait to see the 1/4 times, its not my car
Old Aug 18, 2011 | 05:33 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Those are the kinds of numbers I like to see out of a stroker motor
Old Aug 18, 2011 | 05:34 PM
corvet786c's Avatar
corvet786c
How big of a troke is it? 4.0 inch 4.1 in etc.
Old Aug 18, 2011 | 05:45 PM
dsp300c's Avatar
dsp300c
Cartek built it, 416 stroker 587 rwhp 512 rwtq on pump gas, no meth, cant wait to see the 1/4 times, its not my car
Bracoile?
Old Aug 18, 2011 | 07:36 PM
5knives's Avatar
5knives
Very impressive numbers Mr. Dennis. That other stroker thread kind of died out without much info being shared. Do you have any other information about the build? Like, cam specs, heads, comp. ratio, etc.? Any dyno graphs?
Old Aug 18, 2011 | 08:17 PM
Crowhater's Avatar
Crowhater
I also would like to hear about your engine specs. Was the car an auto or stick?
Old Aug 18, 2011 | 08:34 PM
xstang's Avatar
xstang
Nice build!
I can't wait to see how it runs at the track!
Old Aug 18, 2011 | 08:35 PM
xstang's Avatar
xstang
manual...
Old Aug 18, 2011 | 10:46 PM
LS1LT1's Avatar
LS1LT1
Wow, incredible numbers from what is still a truly streetable combination, I'm betting he could drive that car to California with no problems if he chose to.
A huge congrats to Cartek for makin' it all happen and to '07 416' for stepping it up to the next level.
Originally Posted by dsp300c
Bracoile?
Hey, I remember that guy! LOL
Originally Posted by 07 416
Oh yeah it has a mechanical water pump and a dual disc clutch and made that power. Special Thanks to Julio and the guys at Cartek!
Good point, and 4.10 gears as well. Still a hydraulic cam/lifter set up too.
Not that I would ever consider changing a single thing about this awesome build but I wonder if 3.42s, an electric water pump and a lighter clutch set up could've sent it over 600+rwhp.
I bet all of that ^ along with an aluminum flywheel would've done it.
I want a ride in this thing.
Old Aug 18, 2011 | 10:58 PM
dennis50nj's Avatar
dennis50nj
with everything you said, except i want to drive it
Old Aug 18, 2011 | 11:05 PM
Crowhater's Avatar
Crowhater
So what combination did they put together? I am having a 416 built right now and would like to know.
Old Aug 18, 2011 | 11:13 PM
dennis50nj's Avatar
dennis50nj
forged internals, LS3 block fast 102 and tb trickflow 225 worked heads, cartek cam, cartek tuning, details on parts i don't know
Old Aug 19, 2011 | 10:23 AM
LS1LT1's Avatar
LS1LT1
Im gonna need some seat time with this beast then off to the track
I think you should drive it on the street/highway for a while and just get used to the thing, it's going to be whole different animal now.
And if ya put some miles on it I'd like to see ya maybe do another clutch fluid change just prior to taking it to the track as well.
Old Aug 19, 2011 | 08:43 PM
xstang's Avatar
xstang
Keep us posted, I'd love to see the dyno!
Old Aug 20, 2011 | 08:47 AM
SpinMonster's Avatar
SpinMonster
Its my motor, Cartek did a great job! I couldnt be happier.
its a 416 stroker with trick flow heads its a stick car with 4.10s
You would think as such results with Trick Flow heads on the 4.065" LS3 bore trickle in, that people would get the message that LS3 ported heads would have results that are laughable at best in comparison. I recall an east coast tuner who told me 535rwhp on an LS3 with trick Flow heads was "optimistic". I'm revising the prediction to 545rwhp with a big cam.
Although a stroker here, the bore is still the same as the 6.2L.
Cartek should be applauded for taking the initiative on such a build but then Julio and crew stopped surprising me long ago.
Good job!
Old Aug 20, 2011 | 11:11 AM
CTD's Avatar
CTD
Very nice to see some big numbers!
To bad it's one of those 007 James Bond build's
How is it in gears 1 & 2 @1600 rpm? Mine would pitch you right out the window if it was down.
Old Aug 20, 2011 | 07:38 PM
5knives's Avatar
5knives
Id def go with Cartek, they did a 416 for me I made 587whp and 518 wtq NA. on a dyno that reads low to begin with...
Could you offer more info on this statement please? I'm considering Cartek for possible future work. I don't like getting caught up in dyno numbers but I don't want any dyno tricks being played on me either. What type of dyno do they use? How/who would you compare the dyno numbers with to consider it low?
To 416 stroker
Old Aug 20, 2011 | 08:35 PM
Crowhater's Avatar
Crowhater
In a week I will be running my new 416 that Extreme Horsepower built for me on the dyno and I can relay those numbers also. We just ran my friends new ZR1 on the dyno Thursday and it made 589rwhp and it as 100* in the shop. This is a bone stock ZR1 base Line run.
Old Aug 20, 2011 | 08:36 PM
dennis50nj's Avatar
dennis50nj
its a very good place to go, i have been very happy, no dyno tricks, always a proper tune not unsafe just to get big numbers, i don't care about dyno numbers, just 1/4 times and mph, there motto and shirts say, real performance not just dyno hype, im sure LS1LT1 can tell you more
Old Aug 20, 2011 | 10:58 PM
LS1LT1's Avatar
LS1LT1
A truly awesome C5/C6 LSx specialty shop...and I believe they use a Dynojet dyno.
