View Poll Results: Do you change oil Brand or use stay with same brand
Yes I always use same oil brand
25
96.15%
No I use what is the cheapest
1
3.85%
Voters: 26. You may not vote on this poll
Changing Oil Brand
Old Aug 27, 2011 | 09:05 PM
walker3's Avatar
walker3
Default Changing Oil Brand
Does it affect the engine if you change oil brand (not syn oil, normal oil) each time? I can remember years ago (10-12) I was told that due to the additives that each brand uses that they can affect your o-rings, etc. so best to stay with one brand then if you do change stay with that brand
any truth to that - what do ya'll do?
Old Aug 27, 2011 | 09:09 PM
saplumr's Avatar
saplumr
Need more options. I never buy the cheapest but I do change companies depending on price. But when it comes to synthetics it's Mobil 1.
Old Aug 27, 2011 | 09:23 PM
LS1LT1's Avatar
LS1LT1
I don't think it matters as long as it's a quality, name brand oil.
That being said I do happen to stick with the same oil in my C6 but only because it's great stuff.
Amsoil.
Old Aug 27, 2011 | 09:25 PM
FastGhost's Avatar
FastGhost
Years back it was said that oils from the Penn state was more abrasive
. Pensoil being one of them. Another brand was waxy, leaving a sluge coating on parts.
Old Aug 28, 2011 | 01:54 AM
TRBOKEV's Avatar
TRBOKEV
The stock recomended Mobil 1 is fine for this car.. If you want better I would look into Redline, Motul or Amsoil. All of these premium synthetic oils have higher levels of ZDDP.
You can switch between the synthetics, as they are required by law to be interchangeable. However NEVER mix two brands atthe same time; foaming of the oil may occur.
To Changing Oil Brand
