2005 Automatic Trans Fluid check
Old Aug 29, 2011 | 09:15 AM
Don 79 TA's Avatar
Don 79 TA
Default 2005 Automatic Trans Fluid check
I see the drain plug for the auto trans and wanted to know where the fill plug is and what steps are necessary to check the fluid level
can Dexron III or higher be used?
did you need any special pumps or nozzles to fill it up and does it have to be running to fill it?
this is for the LS2 4spd Automatic Coupe
thanks
Don
Old Aug 31, 2011 | 07:40 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
that plug on the side of the pan is the fill/check level plug. What I did was buy a pump from a boat shop that is used to pump lower unit oil in an outboard engine. It cost about $10 and screws right onto an oil quart. Another thing I did before when I had my c5 was bought a cheap pump up sprayer from the hardware store and cut the tip off so it flowed more volume than with the spray tip. You need to have the trans warm and the engine running when you check it...and level. Good luck. Hope that helps
Old Aug 31, 2011 | 09:17 AM
Don 79 TA's Avatar
Don 79 TA
thanks
that helps me
i do have a pump unit
and even thought about getting a sprayer too like you mentioned
its very close to the exhaust pipe though, doesn't look like fun
regular dexron 3 or higher is good to use?
Old Aug 31, 2011 | 11:53 AM
RicK T's Avatar
RicK T
You "can" use Dexron 3 BUT GM no longer uses or recommends it. As of April '05 Dexron 6 is the only thing used and recommended. 6 is backward compatible with 3 so you don't have to worry about doing a complete flush. Just FYI here's a thread from '05 with GM's announcement of the switch:
http://forums.corvetteforum.com/c6-t...exron-4-a.html
Old Aug 31, 2011 | 01:16 PM
Don 79 TA's Avatar
Don 79 TA
is 6 available at your typical autoparts stores?
Old Aug 31, 2011 | 01:17 PM
Don 79 TA's Avatar
Don 79 TA
from reading that link, isn't that for the 06 model 6spd autos??
Old Aug 31, 2011 | 02:04 PM
RicK T's Avatar
RicK T
Technically that's what the bulletin is talking about, yes, starting with the '06's the Dexron-6 became the "factory fill" standard. But at that time 6 became the defacto standard for all GM auto trans, including older ones.
I'm not trying to convince you of anything, just saying 6 is what is now recommended. You can continue to use 3 but it isn't as good. Here are a couple more discussions if you're interested:
http://forums.corvetteforum.com/c6-t...d-you-use.html
http://forums.corvetteforum.com/c6-t...r-a4-auto.html
Old Nov 14, 2011 | 10:22 AM
motorbreath19842004's Avatar
motorbreath19842004
good info.. thanx
To 2005 Automatic Trans Fluid check
