LS2: Does 160/180 stat change need fan changes?
Old Aug 30, 2011 | 02:21 PM
starkynuke's Avatar
starkynuke
Default LS2: Does 160/180 stat change need fan changes?
I have a stock LS2 Z51. I have read about 50 threads on changing out the thermostat in an LS2...all with pros, cons, arguments for and against.
Here's my plan before my next NASA HPDE track days:
- Swap to a 160 thermostat
- Partially drain and fill coolant mixture with Demin water until relatively diluted and then add Water Wetter (I don't want to argue the merits of WW, our NASA region requires it for TT and Race Group).
Here's my question. After installing the 160 stat, will I need to have some sort of tuning/programming done to alter the fan run temps? My old LT1 Z28 had an option on it's Hypertech Power Programmer that would change the fan operating ranges depending on the stat. Didn't know if there is a similar MUST for the LS2...nobody ever mentions it. If so, how do I go about doing that?
Old Aug 30, 2011 | 03:56 PM
FloydSummerOf68's Avatar
FloydSummerOf68
It's not a must on the LS2 just like it wasn't a must on the LT1, but you'd be missing most of the point of getting the lower thermostat if you didn't have the car re-tuned.
Any handheld programmer or tuning software should be able to do it.
Old Aug 30, 2011 | 06:30 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Mine was reset to come on at 196 by my tuner during tuning. I am running a 180 thermostat.
Old Aug 31, 2011 | 04:04 PM
REVAK's Avatar
REVAK
It is not a "must", but it is recommended to get the most benefit from your stat change. Most hand held programmers will allow fan adjustments, the predator works well for me. Also any tuner guy can do it with hp tuners or similar software.
To LS2: Does 160/180 stat change need fan changes?
