Low Voltage
Old Sep 5, 2011 | 10:15 AM
EVRose's Avatar
EVRose
Default Low Voltage
Went for a drive last night. When I left the house voltage was at 14.2 v. Was driving down the strip stuck in slow moving traffic for about 45 minutes and temp outside was 102º. I noticed at one point the voltage was under 12v on the gauge. I switched the DIC over to voltage and at idle it was 11.8v. Everything was on and working fine. When I got moving it went up to mid 12's. I started to worry so I got off the strip and headed home and out of traffic voltage went up to 13.4v the whole way home but still dropped down to 12 at red lights.
Battery is a Die Hard and is a month old. I charged it for 24 hours when I bought it before installing it. Any ideas on the cause?
Old Sep 5, 2011 | 11:06 AM
KB9GKC's Avatar
KB9GKC
Hello,
Sounds like your alternator is not working properly.
Douglas in Green Bay
Old Sep 5, 2011 | 11:16 AM
EVRose's Avatar
EVRose
Even though it runs back up to over 13v on the highway?
Old Sep 5, 2011 | 11:53 AM
Bill Suttie's Avatar
Bill Suttie
102F ambient at night in Vegas traffic. You had lights on, A/C on and probably full engine cooling fan on. Than is why your voltage was low when the car was stopped. You may be OK.
Old Sep 5, 2011 | 01:19 PM
EVRose's Avatar
EVRose
Yes, everything was on. I was thinking heat had something to do with it. I'm going to check it today and see how it is.
Old Sep 5, 2011 | 09:19 PM
VET4LES's Avatar
VET4LES
I don't think you have a problem. A/C, lights, heat, fans stop and go traffic all cause low voltage. Good luck.
Old Sep 5, 2011 | 11:35 PM
fnsblum's Avatar
fnsblum
Have the battery tested first. Even the Die Hard sometimes dies an early death. The alternator is sized to runs all that at slightly above idle. Later! Frank
Old Sep 6, 2011 | 04:41 AM
RamAir972003's Avatar
RamAir972003
Default My Z06
My O7 Z does the same thing temps are 104 everything is on. I noticed that to at first, then I realized that when you start driving it after you get out of traffic it jumps back up.. Nothing to worry about if was in the 9s then I would worry.
To Low Voltage
