Tire advice please re: drag radials
Old Sep 6, 2011 | 01:08 PM
HOXXOH's Avatar
HOXXOH
I personally think if you want to make a few passes at the track, just to satisfy that urge, then get a pair of tires/wheels for that task. No one at the track will ever care how stock your car looks anyway.
As far as looking stock on the street, the rear tires are the first thing I look at to determine if someone has far more power than what came off the showroom floor. The wannabees don't spend their money on pricy tires that wear out fast, so the ones who do have them are probably not even close to stock. If you want street traction, then get the tires that work the best and forget trying to fool others with a stock look.
Old Sep 6, 2011 | 01:41 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Originally Posted by HOXXOH
I
100%
Old Sep 6, 2011 | 02:17 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by rectifyer2000
It's amazing how many twisted answers a simple question can generate.
What you call "twisted" answers others might call accurate, educated and well informed answers.
Sometimes a simple 'yes' or 'no' answer doesn't quite cut it, especially when trying to help someone keep their very fast 10 and 11 second $50k+ sports car off of the safety barriers.
Old Sep 6, 2011 | 04:22 PM
Le Mans Z06's Avatar
Le Mans Z06
I run Toyo R888s which isn't even a drag radial and my car handles my power fine on the 19" tires. I have 609rwhp and can even roll into the throttle quickly on the street from a dig without a burnout (Nice advantage of the autos). You will be fine running a 19", and a true drag radial will be even better, which I would recommend for tracking the car as the R888s give me a pretty lousy 60 ft (1.85)
Old Sep 6, 2011 | 04:24 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I am not trying to fool anyone. I have never raced another car on the street with my vette. Those days died with my hemi cuda and big block camaros long ago. I just happen to like the stock look and want to keep it as much as possible while having some traction.
thanks for your input.
Old Sep 6, 2011 | 08:16 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by Le Mans C6
I have 609rwhp
Umm, if you're cutting only 1.85 sixty foots with a 609rwhp C6 then no offense but, no, they really don't handle your power fine at all LOL.
Old Sep 6, 2011 | 08:18 PM
Le Mans Z06
Very true, my real point is for it not being a drag radial I am impressed with the tire not getting too sideways. I really haven't tried launching it hard yet, I roll my foot into the throttle and even on the street it's fine which impressed me. I do want to try some M/Ts where I can really get into it out of the gate.
Old Sep 8, 2011 | 05:53 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I thank everyone for the input and advice. I decided to try the MT 19s. I put them on this afternoon so I really cant say too much about them yet. I will really try them out after a few heat cycles and miles. From the little driving I did this aft I can definitely feel the difference in traction. When I push it hard I only get a little chirp into second rather than fishtailing all over the place. I do not know if it is all MT's but they were not easy to balance. They had to move the tires on the rim a few times but they are perfect now. I also found it strange that I didnt have to reset anything in the tpms. Last tire change I did. I have no tc, ah or any other lights or issues so far even though they are about an inch higher than stock.
I will report more on the traction when I get to try them out properly. Thanks again.
I will report more after some use.
The old and new...
It doesnt show so well here but they look great from the rear...
Fine from the side. No sticking out..
And finally they look pretty good on the car in general.
Old Sep 8, 2011 | 10:03 PM
FloydSummerOf68
I think this is a FANTASTIC tire for stock bodied C6's making big power.
Good choice.
Old Sep 9, 2011 | 12:56 AM
LS1LT1's Avatar
LS1LT1
Good choice.
Old Sep 9, 2011 | 08:44 AM
FloydSummerOf68
The fact that it's so much taller than stock might put some people off, but it really does help with giving more sidewall.
I think it was a good design decision in producing the tire.
Old Sep 12, 2011 | 03:03 AM
rectifyer2000's Avatar
rectifyer2000
There are a lot of helpful, really smart, educated and well informed people (like you) on this forum. But many times they take a simple question and "twist" it, providing complicated answers which often times are really not useful to the original post. Sorry to burst your bubble, but he even said as much in a previous post.
Old Sep 12, 2011 | 03:18 AM
  #33
LS1LT1's Avatar
LS1LT1
Yes, he 'sort of' said it in this post:
Originally Posted by realcanuk
My real question is simple. Does anyone have experience with the 19 inch MTs. Will I have decent traction and be able to run low 11s?
I appreciate all this info
Old Sep 12, 2011 | 03:37 AM
  #34
rectifyer2000
Yes he did; he's very polite
Old Sep 12, 2011 | 08:31 PM
  #35
getburnt's Avatar
getburnt
The R888s are GREAT for cornering and do provide better grip than street tires however they spun from a dig when I had my ls3 coupe with only 425rwhp. So no they do not compete with the DRs.
Old Nov 30, 2011 | 07:37 AM
  #36
10mikeymike's Avatar
10mikeymike
Revisiting an older thread here. I'm contemplating buying a set of the M/T 305/35/19 drag radials for my 06 A6 which produces 565 RWHP with 498 RWTQ. I'm currently running BFG KDW2's in 295/35/19 in the rear on CCW SP550 11" wheels. With the current tire/wheel set up my rear tires are perfectly flush with the rear wheel opening. I seem to be finding some conflicting information regarding the section width of the M/T's. Some sources indicate they are 12.5" wide and others say they are 11.5" wide. The BFG's on the car are 11.9" wide so anything wider would stick out past the wheel opening. Does anyone have any experience with the M/T's on 11" CCW wheels? If so can you post pictures or at least confirm the actual width? I'm assuming the larger diameter of the M/T's will also help to fill the gap between the wheel opening and the top of the tire.
Old Dec 2, 2011 | 01:19 AM
  #37
2k5ms's Avatar
2k5ms
have an 05 heads and cam coupe i race quite a bit, i have 19" et streets but plan to go back to a 17" inch et street and put 555s on the everyday wheels.
when it comes to drag radials hoosiers or et streets are the way to go IMO
never had good luck with nittos
To Tire advice please re: drag radials
Old Jan 2, 2012 | 01:31 PM
  #38
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Does Anyone have 19in Mickeys on 11in wheels?
I would really like to see a pic of these before I buy?
I have a feeling that the are going to be to narrow for 11in rims?
Old Jan 2, 2012 | 02:34 PM
  #39
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
305's would fit perfect on a 11 inch rim. i have 305's on my 18x11 wheels. perfection
Old Jan 2, 2012 | 03:12 PM
  #40
LS1LT1's Avatar
LS1LT1
