Do GTO spares fit base (non-z51) front brakes w/o spacers or grinding?
I have a Z51 car, but base rotors/caliper brackets from my road course days. Can I swap on the base rotors/brackets and bolt on a set of GTO spares w/o any spacers or grinding?
Also, just out of curiousity, will I notice a weight savings at each corner going down to base brakes all around?
I'm hoping I can swap out my 19x10 ZR1 replica wheels (~60lbs ea.) for a set of the 17" GTO spares w/ M&H bias plys on them (~27lbs ea.) for a significant weight savings up front.
I'm hoping you meant that the 19x10 ZR1 replica wheels are 60lbs WITH tires, lol.
Also, are you running 19x10s up front?
The GTO skinnies SUPPOSEDLY fit without a spacer up front on base brakes (and yes, you'll save some weight going to base brakes from Z51).
If you look a few posts down you'll also see the option that I'm going after with a Z51 setup which includes running the CTS 18" spares which don't weigh much more than the GTO spares.
I saw your post about the CTS spares and that will be the route I go probably if I cannot fit the GTO spares on w/o modification or spacers.
Received 2,062 Likes
8850 just put the wheel on and slowly tightened the lug nuts equally in the standard pattern. That essentially worked like a broach.
The base rotors vs. Z51 rotors save approximately 15 pounds total, depending on wear of each.
If you search, you'll find many examples like this and posts that confirm.
my gto spares fitting over non z51 base front brakes. no spacer was needed. all i had to do was grind very little out of the hub hole in the middle of wheel, not the car, so it would fit. took me a few minutes. all i had to modify. my videos in my sig also show me running them at the track.
awesome, that's the exact confirmation I was going for. Ordering today
I found quite a bit about using them with spacers and different tire options and even using them as true spares, but nothing that really confirmed if they fit over base brakes w/o modification, thanks for the info
You can open up the hole with a hand drill and a sanding drum. Just go easy and fit to the hub often so you don't take off more than necessary.
No spacers are needed with base brakes. Bolt circles are not the same but again tightening down evenly they do work. Probably best to use whobble nuts.
I guess my only other question would be do people mix bias ply front runners w/ radials in the rear? I'm running nitto nt05r's in back.
debating between these two:
M&H Bias Ply 26x4.5x17 - 11.5lbs - http://www.mandhtires.com/store.php?...on=show_detail
M&H Racemaster 185 /55R17 – 18.5lbs - http://www.mandhtires.com/store.php?...on=show_detail
Cool, I'll be trapping 130mph... I wanted to go as light as possible, but didn't know if it would cause any handling quirks or instability mixing them up like that.
To me the difference would be if you're driving to the track on them or not.
If you drive them on the street AT ALL I'd run the radial fronts. If you swap all of your wheels at the track I'd run bias ply.
Neither are very good for street use. And the bias less than radials.
hmm... I had thought about driving to and from the track w/ them to avoid having to swap there. Would it just be the lack of stability at highway speeds, or ? Hopefully they're relatively stable at speed since I'll be going pretty fast down the track.
The radials will simply handle better at any speed.
If you drive to/from the track get the radials and don't worry about the few pounds difference. The increase in driving ability will far outweigh that small difference and you'll still be saving a ton of weight from stock wheels and full size tires.
I drive 60 miles to and from the track. I'll be going with M&H radials on my skinnies.
You DO NOT want to be caught in a freak shower or find yourself going through standing water on the road with bias ply fronts.
No doubt about it, bias ply are the best for weight reduction, but I consider them a track-only tire. I've driven radial skinnies on the road quite a bit and that's scary enough if you get caught in a bit of weather
I have also found that the radials can last longer/wear better.
