getting CEL from fuel trim lean
later i added a set of magnaflow magnapacks, the killer bee II, and the jim hall tune on the sct tuner. now the light started coming on more often and for longer. i finally came around to using the sct tuner to tell me what was wrong and the CEL is from P0171 and P0174 (if i remember correctly). they are both fuel trim lean codes.
anyone know how to tune it a little richer or do i just need to scrap the hand held tune business and take it to a real tuner? i was planning on waiting until i scrapped the magnapacks and put on a set of headers before getting it tuned. id hate to get it tuned now and then have to re do it when i go to headers in the near future.
any recommendations?
oh, and edit to add: i never checked the codes before i put the tune on. so, i really dont know what the previous CEL was for. im guessing it was for the same, but im thinking i should remove the tune and see if the CEL reappears, and check the code then.
1) Re-installed the radiator shroud and used black gorilla tape to hold it in place tightly. GM came out with a TSB saying if you got these codes to check the radiator shroud since it was allowing unusual airflow into the air inlet to the engine.
2) I had added an air/oil separator, so I added 4 hose clamps to the ends of the rubber hoses leading to and from the separator. (could have been a vacuum leak)
3) I re-tightened the intake manifold (I had it off a while ago for porting). Kind of surprised me that some of the bolts were a little loose.
4) I cleaned and re-oiled (lightly) the air inlet filter.
5) I cleaned the MAF with MAF cleaner.
OK, I did this over 2 months ago and I haven't had the codes. So which thing that I did fixed the problem? I have NO CLUE! But all the things I did were easy to do and most needed to be done.
