Oil filters
Sep 19, 2011 | 11:23 AM
Oil filters
AC Makes an UPF48R Oil Filter that is Black WILL THIS ONE WORK ON MY LS2 07' COUPE?
Reason: INFORMATION
Sep 19, 2011 | 01:17 PM
UPF48R oil filter
Quote:
Originally Posted by
LKicklight
Yes, it will fit your LS2 just fine. I use this oil filter in my 2007 LS2.
Too bad my dealer doesn't keep stock of this filter but I do.
Sep 19, 2011 | 02:10 PM
Randy: You can get them from Gene Culley at GMPartsWarehouse for about $10 each.
Joel
Sep 19, 2011 | 08:51 PM
Sep 19, 2011 | 09:08 PM
St. Jude Donor '09
LKicklight
Is it just the color you're going for? Or does this filter do a better job? Or higher capacity? Or... ?
Sep 19, 2011 | 09:34 PM
73sbvert
It has a much better micron filtering capacity without restricting the oil flow. I believe it standard on the late model Z06's and the ZR1's.
Sep 21, 2011 | 12:34 PM
Redrocket1045
It also has a higher pressure rating.
Sep 21, 2011 | 04:09 PM
St. Jude Donor '09
Redrocket1045
goatts
Aaahhhh! Thank you both! I'll hunt for some now too!! If I find a good price on them somewhere, I'll post up!!
Sep 21, 2011 | 07:27 PM
I bought 2 of these last year from summit racing, I think they were like $26.00 with shipping. Best price I found!
Sep 21, 2011 | 08:54 PM
Premium Supporting Vendor
The LS2 requires the UPF44 and not the UPF48R. I will double check my memory, but I'm pretty certain I am correct.
Sep 21, 2011 | 09:09 PM
Gene Culley
I think you are correct...the UPF44 is shorter than the UPF48..
I "think" the 48 will hang down a lot lower than the oil pan...the 44 is shorter and will be about even with the bottom of the oil pan...
Please correct me or if I'm right let me know so I'll be sure to order the correct oil filter next time...
jpee
Sep 21, 2011 | 09:13 PM
I think the 48R is only required on the dry sump engines because of the higher oil pressure! I have a GS with the dry sump
Sep 21, 2011 | 09:38 PM
Gene Culley
The 2005 & 2006 LS2 takes the PF44/PF46/UPF44 filter and the 2007 LS2 takes the PF48/UPF48R filter. The two are not interchangeable. Besides having two differerent mounting thread size and pitch, the PF44/PF46/UPF44 does not have a bypass valve. The PF48/UPF48R has a bypass valve installed as the engine does not have the bypass valve included.
Sep 21, 2011 | 10:14 PM
Correct
Your are son right my friend..knew I should have pulled the other one off to see..I need two right away..
LKicklight@aol.com
Gene Culley
Sep 22, 2011 | 12:59 PM
LKicklight
LKicklight@aol.com
Did you read my post #13 above? You posted that you have a 2007 LS2. The 2007 LS2 uses a different filter then the 2005 LS2 and the 2006 LS2.
Sep 25, 2011 | 04:25 AM
St. Jude Donor '13-'14-'15-'16
Redrocket1045
Incorrect. It has the exact same internals, just rated for higher pressures.
"TIP: The internal components are the same in both the UPF48R and PF48 oil filters. The UPF48R can be used in applications where the PF48 is specified."
http://www.sandyblogs.com/techlink/t...ptember_09.pdf
Sep 25, 2011 | 09:44 AM
JoesC5
Correct, my 07 LS2 takes the PF48 Oil Filter. It's in the Manual.
Sep 25, 2011 | 10:56 AM
Gene Culley
Not entirely correct Gene. GM changed the 2007 LS2 to the 48 series. So only the 05 and 06 LS2s take the 44/46 series.
Sep 25, 2011 | 10:58 AM
JoesC5
Exactly correct.
Sep 25, 2011 | 11:00 AM
j_digi454
I have used both the PF48 and UPF48R on my vert 07 LS2 as well.
