Special Torx Bit for MAF Sensor?
Old Sep 20, 2011 | 08:04 PM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Default Special Torx Bit for MAF Sensor?
The screw apparently takes a tamper-proof, 5 lobed torx bit. Anyone know where I can get one? It's beyond me why these idiots come up with something like this and then sell a tool to take them out! I've tried a couple of places with no luck. Haven't been able to catch the MATCO or SnapOn guy yet. I figure they probably have it. Anyone find one yet?
Old Sep 20, 2011 | 08:14 PM
JoesC5's Avatar
JoesC5
I tried to find one locally, to no avail. I did find some for sale on the net.
Old Sep 20, 2011 | 08:16 PM
edmundu's Avatar
edmundu
These are very hard to get locally. Ebay or online store would be your best bet....
IF you only need to remove the screws, I was able to do so with just needle nose pliers. They are not that tight, and will come off pretty easily.
Needle nose vise grips would be pretty good also, and then just replace those POS screws with regular torx, or whatever is provided with the intake you are swapping to
Old Sep 20, 2011 | 08:28 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
Jim Hall, Halltech, sells the tool/bit that you need.
Old Sep 20, 2011 | 08:34 PM
Delbert's Avatar
Delbert
You can pick one up from Halltech. Order online:
http://www.halltechsystems.com/WIHA_...s_p/171654.htm
Halltech's supply may be limited, so it is also available here:
http://www.wihatools.com/700seri/716_IPR_serie.htm
Old Sep 20, 2011 | 08:48 PM
DSOMC6's Avatar
DSOMC6
Amazon should have it. Although you'll probably pay more for shipping than you will for the bit.
Old Sep 20, 2011 | 09:16 PM
torquetube's Avatar
torquetube
Tamper-resistant or security Torx PLUS is the search term you'll need.
Old Sep 20, 2011 | 09:29 PM
djbrun's Avatar
djbrun
I purchased a set from auto-zone.
DJ
Old Sep 20, 2011 | 09:59 PM
AirBusPilot's Avatar
AirBusPilot
I used a T15 torx.
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Says you're in Tampa, I don't know of any warehouses in Tampa, but, over here on the right side on you can get the kit here
http://www.aimsupply.com/
7337 Bryan Dairy Rd.
Largo, FL 33777
Phone: (727)544-6114
http://epartners.aimsupply.com/store...=1&numResults=
Take the 118th Ave exit off of 275 South and head west. It will be just past 66th St on the right. Nestor Sales
Old Sep 20, 2011 | 10:20 PM
dmass123's Avatar
dmass123
The correct size torx bit is a T-20. You should be able to pick one up at any parts store, sears, lowes and so on. Looks just like a screw driver except has the torx end. These have been around for years, i have had a set sense 1984 to remove the plastic facings around headlights on 84 model gmc truck. use them all the time to adjust headlights on all late model cars and trucks.
Old Sep 20, 2011 | 10:32 PM
JoesC5's Avatar
JoesC5
99% of the torx screws in use are of the 6 lobe design. The screws in question have a 5 lobe design and not all year C6's have the 5 lobe. Just because someone posts that their C6 uses a 6 lobe torx screw, does not mean that all C6's use a 6 lobe torx screw.
Old Sep 20, 2011 | 10:48 PM
edmundu's Avatar
edmundu
Sooooo true! I found out mine was one of the 5 lober's, after I had taken it apart, and I almost wound up ordering a bit online, after looking everywhere locally.....
But thankfully my fellow bro's here suggested trying needle nose pliers, and they worked like a charm.
OP,
I would save the $$$ and not bother with the bits, for this one time use. Unless there are other's lurking within the car???
Old Sep 20, 2011 | 11:05 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
http://www.amazon.com/Torx-Driver-Se.../dp/B0002SPLQ8
Old Sep 20, 2011 | 11:09 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Lisle Tools has a full set for $7.95 Found it a O'Reilly Auto Parts. They were in the section with the torx bits for brakes.
Old Sep 20, 2011 | 11:51 PM
r2swift's Avatar
r2swift
Try radio shack, Believe it or not found a hard to find one there Awhile back. good luck.
Old Sep 21, 2011 | 07:50 AM
JoesC5's Avatar
JoesC5
Thanks. I looked all over O'Riellys for a 5 lobe torx, to no avail. I'll recheck in the brake parts section as I didn't look there.
To Special Torx Bit for MAF Sensor?
Old Sep 21, 2011 | 09:24 AM
AirBusPilot
You're talking about the torx screws that hold the MAF to the plastic airbridge?
Old Sep 21, 2011 | 09:48 AM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Yes, on my 2011, it takes a five lobe, tamper resistant Torx bit.
Old Sep 21, 2011 | 10:04 AM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
I need the tool for more than one use, so I'd like to get the right one.
Thanks.
