Inner CV Joints leaking again--4th time
Old Sep 21, 2011 | 04:47 PM
Car54's Avatar
Car54
Default Inner CV Joints leaking again--4th time
Each year for the past 3 years the inner CV joint boots have started leaking on my '06. Each time the replacement has been done under warranty. This time I am 3 months out of my 12 month gm parts warranty and I have to foot the bill. About 200 for parts and 200 for labor per side. So has anybody else had to replace CV joint boots this often? It has about 47k miles....and yes I do HPDEs several times a year. Can anyone tell me what causes them to leak outside of the obvious puncture of the boot by a piece of road trash?
thanks
Old Sep 21, 2011 | 06:18 PM
REVAK's Avatar
REVAK
thanks
My best guess would be heat. [ my 06 has all original boots, 32k mikes]. Perhaps someone who does hpde will chime in , perhaps there are higher temperature rated boots available. Silicone ?
Old Sep 21, 2011 | 07:01 PM
V8ANGER's Avatar
V8ANGER
thanks
The dealers work covers the labor and parts for a year from the last repair. Dig out your old receipt and hope it hasn't been past 12 months ago. Also because you brought it in the last three times for the same repair it should be covered under warranty even if the warranty ran out because they can't seem to fix the problem. I'd recommend speaking to a lemon law attorney.
Old Sep 21, 2011 | 08:26 PM
Car54's Avatar
Car54
Heat is always an issue but I can't imagine that I am producing 4 times more than any one else running hpde's. I added up the tools that are required in the service manual...minus the slide hammer...from the kent-Moore website and the total was $300. Can anyone tell me if this is something a do it yourself person can do?
Old Sep 21, 2011 | 09:49 PM
TMyers's Avatar
TMyers
I have only replaced one and that was because I damaged it. 40K on the OD.
To Inner CV Joints leaking again--4th time
