Bolt On 500HP Package, C6 LS3 less than $2500
500 - 436= 64
64hp = headers/tune?
That's all it takes to match an LS7?
My personal observation has been that manual trans Corvettes are running about 10%-11% drivetrain loss on the dyno myself and a few other locals use. My buddy with a bone stock Z06 was at 454rwhp. Most LS3 Corvettes are at 380-390rwhp on that same dyno.
OP, in your post.
Numbers do not add up over stock unless you meant to say 50RWHP and 35RWTQ over stock which is believable since you're basing this off an Auto which needs tuning off the factory floor to wake it up.
I however do not believe in the 500hp label for the package. But you're not the first nor last to do this. Plenty of shops and aftermarket products do the whole add X amount of hp with this performance part. So most guys should know better than to expect advertised power gains unless it's backed up with a money back.
This 500HP package has gains of over 50HP and 35FTLB over stock almost and almost a .5 second reduction in 1/4 mile times.
There is no static # for drivetrain loss. As power goes up,drivetrain loss(as a percentage) goes down.
20 percent for automatics and 15 percent drivetrain loss for manual is accepted ...
Thanks for the heads up on your offered package to accomplish 500 hp...or there abouts..
#33
Question on Tune
Bolt on performance that is proven! We take all of the guess work out of making power by providing you our street, track and road course proven packages for your C6 LS3 Corvette. This 500HP package has gains of over 50HP and 35FTLB over stock almost and almost a .5 second reduction in 1/4 mile times.
Torq C6 LS3 500HP Package - MORE INFORMATION HERE
http://www.youtube.com/watch?v=tj3YR...layer_embedded
I have a 2011 GS 6 Spd. It already had AR Headers, high flow cats, Vararam cold air and a canned street tune. It has the stock NPP exhaust.
Can you send me a PM on what you would charge to either data log and tune again vs dyno and tune.
Thanks,
Jim
#34
I gained 47 rwhp with the mods in discussion. LS3 MN6 Came in at 422 rwhp 470 ish at the fly wheel.
Going to need a cam to get to 500 rwhp and a big one at that.
#35
This thread is 6 years old and i would never buy anything from someone that makes such vague claims. Modern cars do not have that much drivetrain loss and it is not calculated that simply.
#37
Received 3,043 Likes
St. Jude Donor '05
OP dont get sucked into the dyno # arguement, most will never spend a dime anyways and noone will feel 5-10hp let alone the fact dynos almost never read the same.
Bench racing
Good luck
Bench racing
Good luck
#38
