C6 exhaust question
Old Sep 28, 2011 | 11:27 AM
scamilleri1228's Avatar
scamilleri1228
Default C6 exhaust question
I bought a used c6 z with corsa exhaust on it. When driving the car I would hear a squeak from what I thought was the hatch but later figured out was the exhaust. The springs seem to rub on themselves and I'm just wondering if this is normal or it's an aftermarket spring causing the issue? I tried to put some plastic tubing around the spring to quiet it down and it's worked so far. The springs are near the rear end of the torque tube.
Old Sep 30, 2011 | 09:46 AM
scamilleri1228
No one knows?
Old Sep 30, 2011 | 11:51 AM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
I'm not familar with this issue however, You might try to rub some type of grease or even WD-40 on them to help with the squeak. If that doesn't work for you then you will need to remove the springs and re-adjust.
Old Sep 30, 2011 | 03:13 PM
Drevil's Avatar
Drevil
I had the same problem. I put Zip ties on them. Have not had the problem since
Good luck
To C6 exhaust question
