Oil Overfill
Old Oct 1, 2011 | 10:59 AM
fastcarz06's Avatar
fastcarz06
Default Oil Overfill
Just had my oil changed on my standard C6 at the local Chevy Dealership. I doubled checked the oil level when I got home and found the oil level on the dip stick read above the top line on the dip stick, probably about a 1/4 of a inch. I believe that they put in 6 qts. instead of the 5.5 qts. that is recommended. Should I go back and have them remove the extra or will this not hurt anything. I thought about getting ramps and start changing it myself and now I think I will from now on. Any suggestions are appreciated.
Old Oct 1, 2011 | 11:23 AM
Don 79 TA's Avatar
Don 79 TA
personally i dont see it as a problem
i know on my TA i've been told its ok to even go a qt above, especially if i turn high rpms so the pan doesnt drain out (ok this applies more to 1/4 mile racing situations)
some builders will add 2qts instead of a large pan... call it a sleeper effect
and i've had that info from 3 very well know engine building shops (Butler, Hendrick, and Shafiroff)
road racing... that would be a different story
some will also say that can hurt by having to much in (lower splashing issues)
but a 1/2 over not a major concern
could always pull the filter to remove some
but again... not needed
just my thoughts
would i say something the next time at the shop, couldn't hurt
Old Oct 1, 2011 | 11:31 AM
DSOMC6's Avatar
DSOMC6
No worries...It wont hurt anything. Some like to dump in a little extra when running at the track.
Old Oct 1, 2011 | 12:02 PM
Honch's Avatar
Honch
Page 4-14 of the owners manual:
Racing or Other Competitive Driving
[Except Z06 and ZR1: Be sure to check the oil level
often during racing or other competitive driving and
keep the level at or near 1 quart (1 L) above the upper
mark that shows the proper operating range on the
engine oil dipstick. After the competitive driving,
remove excess oil so that the level on the dipstick is
not above the upper mark that shows the proper
operating range.
Page 5-20
When to Add Engine Oil
(Except ZO6 and ZR1)
Notice: Do not add too much oil. If the engine
has so much oil that the oil level gets above the
cross-hatched area that shows the proper operating
range, the engine could be damaged.
Old Oct 1, 2011 | 12:32 PM
REVAK's Avatar
REVAK
In my experience, 1/4" above the line is likely a half qt. , or less . I would not worry or bother about it. A full qt. or more above could cause foaming or aeration in normal driving conditions. IMHO.
Old Oct 1, 2011 | 12:48 PM
tomiboy's Avatar
tomiboy
operating range.
Page 5-20
Hard to believe such a contradiction in the same owners manual. I'm going to a track day on Monday and just added 1 quart. That final statement concerns me. I wonder what kind of damage would happen on the street that doesn't happen pushing it on a road course?
Old Oct 1, 2011 | 03:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The tech at our local dealer says it's too easy to mistakenly underfill some of the C6s, so he just puts 6 qts in all the dry sump engines.
Mine is supposed to take 5.5, but it really takes about 5.75 to get to the full mark. So I'm overfilled by about .25 qt, that's fine with me. Anything up to .5 qt over shouldn't be a problem.
Old Oct 1, 2011 | 04:15 PM
Honch's Avatar
Honch
Its not really a contradiction, its very clear for normal driving they don't want it overfilled.
Old Oct 2, 2011 | 12:38 PM
KB9GKC's Avatar
KB9GKC
Hello,
During hard driving the engine is at high RPM spinning the oil pump very fast. The engine oil gets pumped to the top of the engine quicker than it can drain back down. Under these conditions the crankcase level can become low and an additional quart of oil will alleviate this issue.
Under normal driving the extra oil level gets aerated from the spinning crankshaft and aerated oil doesn't lubricate as well and that can lead to engine damage!
Douglas in Green Bay
Old Oct 2, 2011 | 01:23 PM
tomiboy's Avatar
tomiboy
Originally Posted by KB9GKC
Hello,
Thanks, I figured someone would know the answer!
Old Oct 2, 2011 | 02:03 PM
BoosterClub's Avatar
BoosterClub
For road racing the downsides don't outweigh the upside of not starving the engine. In addition, the downside is fairly mitigated since the oil does not sit in the pan. It spends so much time at high RPM a lot more oil is being pumped, so more oil is "in the engine" rather then in the pan, like in the cylinder heads waiting to drain down. That in addition to the high G forces, more oil is better.
Cruising down the street, low rpm, all that oil is just sitting in the pan. The danger is extreme aeration of the oil as it is closer to the wind-age of the crank and such, or in an extreme situation, make contact with the crank. If the oil is aerated to much and froths it does not provide the same lubrication = far increased wear.
I hope this helps people understand the seemingly contradiction.
Hello,
thats what I get for stopping one post above yours.
Old Oct 4, 2011 | 05:09 PM
ScaryFast's Avatar
ScaryFast
The extra quart on the track is also to help keep the oil pick up submerged when cornering and braking. Oil can slosh to the front or to one side and starve the oil pump.
Old Oct 4, 2011 | 08:32 PM
Bill Dearborn's Avatar
Bill Dearborn
If you notice the only paragraph that mentions severe engine damage is the one for the dry sump engines. Nothing is mentioned for the wet sump engines. I always added the extra half quart when filling my C5 engines and in 12 years it never hurt anything. With the C6Z and the dry sump I add to the top line after checking the oil when it was warm and the car had sat for 5 minutes. Going over that line can increase pressure and cause severe leaks that is what is meant by engine damage.
Bill
Old Oct 4, 2011 | 09:39 PM
Robls6's Avatar
Robls6
It's also to make up for windage. During high RPM driving over a quart of oil can be suspended around the crankshaft as oil mist (windage).
Old Oct 5, 2011 | 08:30 AM
el es tu's Avatar
el es tu
I always run 6qts. Never had any problems.
Only downside is a higher possibility of oil collecting in the intake manifold from the pcv system.
To Oil Overfill
