Cold Air Mod?
Old Oct 3, 2011 | 09:31 AM
jost6453's Avatar
jost6453
Default Cold Air Mod?
I have a 2011 GS coupe with 6spd manual tran and I'm interested in getting a little more hp by providing cooler air to the intake. I'd like to preserve the stock setup, but possibly modify the shroud in front of the radiator to provide cooler air to the filter. I'm sure there must be posts out there on this, but haven't found the 'right' one that cleary explains pros and cons .... and 'how to'. If anyone can steer me in the right direction, that would be great. Thx. -DJ
Old Oct 3, 2011 | 12:10 PM
LS1LT1's Avatar
LS1LT1
Here's one of the better write ups on it:
http://forums.corvetteforum.com/c6-t...gle-bolts.html
Old Oct 3, 2011 | 12:30 PM
speedraider's Avatar
speedraider
prepare for some surging with out a tune on LS3.
Old Oct 3, 2011 | 02:47 PM
jost6453's Avatar
jost6453
I checked the link, ...looks easy. Please elaborate on the surging. Is it due to turbulence or the much cooler intake air?
Old Oct 3, 2011 | 07:08 PM
JoesC5's Avatar
JoesC5
The LS3/LS7 MAF's do not like the turbulance from a mod made to the shroud. I installed a Vette-Air scoop and had to make a flat diffuser plate to cover the discharge side of the scoop to keep the forced air from being directed into the mouth of the breather on my Z06. After installing the diffuser...zero surging.
Old Oct 3, 2011 | 08:12 PM
speedraider
turbulence
Old Oct 3, 2011 | 10:01 PM
jost6453's Avatar
jost6453
Good to know. I'm not intending to create a forced air sytem that would create a lot of turbulence..... but would like to introduce some fresh air to the intake. One thought I've had is to use hole saw (maybe 1.5" dia) and cut a series of holes in the shroud in a line (side to side) just behind the bumper and under the intake. This would allow fresh air in, but it wouldn't be forced and I wouldn't need to worry about water being ingested. I'm in no hurry so will give it more thought.
Suggestions, concerns??
Old Oct 4, 2011 | 01:27 AM
Mike's LS3's Avatar
Mike's LS3
Go on Jim Haltech's website and look up how to install cold air ports on the oem shroud using the Beehive Shroud. You can open two elongated holes at the lower ends of the oem shroud to introduce fresh air. Install the Beehive Shroud to keep the hot air out of the air intake bay. I used this method both with the Killer Bee air intake and modified the Beehive shroud to fit the oem intake. I have no issues of surging with either set up. The open cold air ports work best with the Beehive Shroud which helps to prevent hot air entering the air intake.
Old Oct 4, 2011 | 08:37 AM
jost6453's Avatar
jost6453
Thanks for the post. Rather than using a shroud, I'm considering just closing off the openings on either side of the air filter hsg (up front by the bumper). I'll check Jim's site.
Old Oct 4, 2011 | 01:58 PM
jost6453's Avatar
jost6453
I'm not finding this 'how to' guide. Can someone direct me to it? I'd like to open up the shroud on my LS3 to allow some fresh air in ....but definitly don't want surge trouble.
Old Oct 4, 2011 | 03:09 PM
Mike's LS3's Avatar
Mike's LS3
Go to www.halltchsystems.com. At the top right side of page, click installations. Click Beehive Ram air installation, instuctions are both in writting and a video format. Good luck.
Old Oct 4, 2011 | 04:57 PM
jost6453's Avatar
jost6453
Many thanks for directing me to the instllation link.....
Good videos. Apparently there are two setups, ram air vs not? For the non-ram air setup, where is the intake air drawn from? Still under the hood? If so, the why the 'beehive? on top? .... just appearance?
Old Oct 4, 2011 | 06:10 PM
Mike's LS3's Avatar
Mike's LS3
The non-ram air set up is for the Z06 and GS which both have a front nose air duct that allows in cold air flow. However, opening the lower oem shroud ports allows more air flow that reduces the temps inside the shroud quicker when leaving a stop light. Also the open ports work for base coupe which has no front air duct. If no ports are open, as with the base coupe, air will still come in around the bottom frame rails. The idea of the Shroud is to prevent hot engine air entering the air intake. Once ambeint air reaches 86* F, the ECM, engine computer management, starts to pull timing which reduces hp.
Old Oct 4, 2011 | 07:23 PM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Be very careful cutting the shroud. The AC condenser is behind the shroud and very easy to knick. It's happened to several on here and it's an expensive repair.
VOICE OF EXPERIENCE!
Old Oct 4, 2011 | 09:03 PM
jost6453's Avatar
jost6453
Thanks to all. I didn't realize until taking a close look after work tonight that the front duct was actually funtional. That explains a lot.
Old Oct 5, 2011 | 08:34 AM
jost6453's Avatar
jost6453
btw ....does anyone make a cover (similar to the beehive cover) for stock GS models? It seems like there would be some performance improvement by ading a K&N filter and shrouding the intake to keep the hot air out.
Old Oct 5, 2011 | 12:07 PM
Mike's LS3's Avatar
Mike's LS3
Not enough demand for it, however some forum members made their own. I used Halltech's Beehive shroud for the Killer Bee 1 air intake and trimmed the shroud to fit the oem air intake. I made a cardboard template of the oem air intake opening and traced the opening onto the Beehive Shroud. Basically, just trimed the air bridge opening to allow the oem air intake to fit. Results: oem air intake with shrould and cold air ports and no surging issues.
To Cold Air Mod?
Old Oct 5, 2011 | 12:08 PM
80&09vettes's Avatar
80&09vettes
I have a 2009 Coupe and did the Vette-Air and Airaid combo. It works great with no surging a noticable performance improvement. I am very pleased with this mod.
Old Oct 5, 2011 | 01:39 PM
S'vette's Avatar
S'vette
Dec and Jan.
Old Oct 5, 2011 | 03:04 PM
speedraider
you got lucky
