OBD-II Question
Old Oct 6, 2011 | 11:38 PM
Corvee's Avatar
Corvee
Default OBD-II Question
I installed a data-logger with a OBD-II connection and would like to monitor my oil pressure and oil temps from the ECU. In order to read them, I have to load the sensor hex address and an equation into the logger. Any ideas?
Jim
Old Oct 8, 2011 | 12:59 AM
frankgtb's Avatar
frankgtb
very interested in logging temps speeds laptimes etc etc etc
what datalogger are you using?
Old Oct 8, 2011 | 08:24 AM
Corvee's Avatar
Corvee
A RLC Micro Pod. It has OBD-II read and GPS track mapping capability so you can compare your data (i.e. throttle position, brake pressure) to your lines. Wish I had further information on the OBD-II codes. There is significant information read by the ECU if you can decode it.
To OBD-II Question
