MODIFY LS2 MAF sensor. DE-SCREEN
Old Oct 8, 2011 | 07:28 AM
PETEGIFFEN's Avatar
PETEGIFFEN
Default MODIFY LS2 MAF sensor. DE-SCREEN
WILL DOING THIS EQUAL A SIGNIFICANT INCREASE IN AIRFLOW? VERSE BUYING A LARGER MM MAF SENSOR???? PETE...
Old Oct 8, 2011 | 10:18 AM
REVAK's Avatar
REVAK
This topic is much debated here. I am from the de screen camp. I have de screened every LS1 and LS2 I have ever owned. [ 6 and counting ] . I haven't experienced any problems, the throttle response improves, the air flow improves by 10 to 12 % . You should adj your LTFT's for 0 to -2% . If you search this forum , there is much pro and con on the topic. The ZO6 factory MAF does not have a screen.
Old Oct 8, 2011 | 07:09 PM
COVERT GUY's Avatar
COVERT GUY
Descreened every LS1 and LS2 I've owned, which is 9 and counting, easy 3 rwhp without affecting driveability and I did not retune the vehicled. Yes, I actually have dynoed before and after the mod on 3 occassions, helps to be a owners friend. Revak is right about the 10-12% increase in airflow.
To MODIFY LS2 MAF sensor. DE-SCREEN
