Corvette Mods FOG Light Question(s)
Old Oct 10, 2011 | 10:40 PM
Eminitrader's Avatar
Eminitrader
Default Corvette Mods FOG Light Question(s)
CM: I left you a voicemail tonight - figured I'd put the question out here too..
Ok - installing the Fog Light Kit from Corvette Mods (By the way, the headlights installed great and they are fantastic)
I have 2 concerns/problems
1) I can't get any light out of the bulb. The large red connector from the ballast is connected to the the car - where the bulb came out of I plugged that part in the ballast.
The other 2 connectors I have plugged into the bulb connector - nothing. I only have 1 side connected (so I could figure out how to put it all back together). WHen I turn on the fogs the factory works fine but the HID does not. I unplugged the ballast and plugged it back to factory and the factory bulb worked fine.
I tried the 2nd HID and same thing - nothing. This leads me to believe I am doing something wrong.. Any ideas?
2) THe bulb itself really doesn't seat well inside the lens. I mean, it goes in there but it seems it could come out fairly easily. Am I missing something here?
SO far - I've done the LED's and the headlights - all good! Very pleased. Just really want to get the fogs done and button this baby back up.
As always, I appreciate any and all help!
David
Old Oct 10, 2011 | 11:01 PM
Eminitrader
Here are a couple of pics:
Old Oct 10, 2011 | 11:35 PM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
Dave
Your polarity is incorrect. Reverse the harness from your car to the red wire from the ballast. Just pull it apart, turn 180, reinstall
David
Old Oct 10, 2011 | 11:44 PM
Eminitrader
Worked like a charm, or should I say a LIGHT! LOOKS AWESOME. Very noticeable difference.
I just showered because I did not expect to hear back from you at nearly midnight. But I am heading down to do the other side!
You rock! I emailed you a couple quick questions too..
Thanks!
Old Oct 11, 2011 | 01:46 AM
Eminitrader
Wow. The first one took a lot longer than the 2nd one did all working now good... whew what a day..............
Old Jan 14, 2012 | 04:22 PM
nrt69's Avatar
nrt69
i just experienced the same problem.
why not make the clip so it attaches the way you would think to attach it?
i should have pics of my stealth DRLs, clear side marker lenses, and HID fogs with GT2 yellow covers by tomorrow! (if i can figure out how to upload pics)
To Corvette Mods FOG Light Question(s)
