Mild to wild $89.95
WE HAVE THE SOLUTION THE MILD TO WILD SWITCH.
IT USES WIRELESS REMOTES TO GIVE YOU CONTROL OVER THE VALVES IN THE EXHAUST. INSTALL IN MINUTES. IF YOU CAN USE A SCREWDRIVER YOU CAN INSTALL THIS IN LESS THAN 20 MINUTES.
ALOS WORKS WITH THE B&B FUSION EXHAUST.
http://www.corvettesofhouston.com/pr...c573a28b5f5140
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
