Hi Guys:I have a 08/Z51/A6.I had my car realigned at about 15,000 miles to the base corvette specs.I had Firestone's RF's put on about 10,000 miles ago.My rear tires are wearing even,but the front tires seem to be wearing more in the center ? I keep my air pressure around 31psi on all 4 tires.I'm thinking that it needs to be aligned again.I donot track the car,so does any one have any recommendations for alignment specs for a DD.I will take it to a good tire shop,not a damm dealer.........Thanks...
When you say that your tires "seem to be wearing in the center" that implies a casual observation and not an accurate measurement. If they are in fact wearing more in the center of the tread, that is due more to over pressure than alignment. 30 psi cold is the prescribed tire pressure. Deviation from that will affect the wear pattern of the tire.
True,same if you run low air pressure they will wear on the outer part of the tread.I checked them out more closely and the outer edge has more tread,the center to the inter is even ?Looks like a toe in problem ?
You're welcome.
But I don't consider my diagnosis to be a final word. If you don't get more replies in a couple of days, you might try posting under C6 General.
That will probably get some replies that are goodfy or wrong, but you can develop a concensus in the group. Best of luck to you.
BTW, a tread depth gauge can be invaluable for this kind of work. Less than $10 at the parts store, if they carry 'em.
I even keep one in the car to help diagnose tire wear problems on loooong road trips.
