Launch control
Old Oct 21, 2011 | 01:04 PM
ROD BROWN's Avatar
ROD BROWN
Default Launch control
I am curious.What is launch control and how it works. Thanks.Rod
Old Oct 21, 2011 | 04:13 PM
B y r o n's Avatar
B y r o n
Engage launch control, aim car straight ahead, gas pedal to the floor - engine with only go to 4,000 RPM, side-step the clutch and keep the gas pedal floored and hold on.
Old Oct 21, 2011 | 07:57 PM
68sixspeed's Avatar
68sixspeed
St. Jude 15 Year Donor
St. Jude Donor '10 thru '26
I've only tried it twice on my GS, seems pretty useless, tons of tire spin, I can get a better launch myself.
Old Oct 21, 2011 | 08:50 PM
JLargo's Avatar
JLargo
This^^ but you first have to put it in competitive driving mode.
Old Oct 22, 2011 | 12:42 AM
ROD BROWN's Avatar
ROD BROWN
Thanks for the explanation. What year was this introduced to the Vette and is it an accessory or standard equipment? Rod
Old Oct 22, 2011 | 01:54 AM
jon6.0's Avatar
jon6.0
I would like to know also before I try it, lol.
Old Oct 22, 2011 | 04:04 AM
c5z16z's Avatar
c5z16z
launch control was introduced for vettes and camaros for 2010 models im not sure if all trims get it but u sure should be in competitive mode to get rid of some tire spin...
Old Oct 22, 2011 | 04:48 AM
itsaz's Avatar
itsaz
St. Jude Donor '09
Anything less than full throttle will not engage launch control. If you're getting that much wheel spin, you ain't doin' it right!
Old Oct 22, 2011 | 08:54 AM
68sixspeed's Avatar
68sixspeed
It did stop at 4k with wot, so it was engaged... Maybe it doesn't know what do do with cooler roads, but it was in the 60's when I tried it, not like it was 40 out. I just think it's a lot of hype... Even watching the videos when it was introduced, quite a bit of spin. From drag racing I can tell you, wheel spin is not the fastest launch.
Unlike some of the hypercar systems the computer has no control on the clutch, so it's only able to modulate the throttle.
Old Oct 22, 2011 | 01:05 PM
70goat's Avatar
70goat
I have drag raced for 30+ years in a variety of cars and currently have a 9.40's GTO (NA) . I dont compete with my Callaway but took it to a street event at our track for a what will she do session. I ran multiple passes , the best being a 12.01 @ 126 mph ( air was over 4000 ft and actual is 2300 ft). As someone who knows how to launch a car i could not match that time without the launch control activated. i was on street tires so it was not a controlled test by any means. Launching with the control activated got me down the track with short times consistently in the 1.90 range which i could not replicate with the system turned off. Yes the tires spun but way less than with me trying to feather the throttle and the clutch at the same time.
i came away sold that it operates better than me and it is 100% consistant.
Old Oct 22, 2011 | 03:42 PM
Kerrdogg's Avatar
Kerrdogg
I tried it once at the track and all I got was wheel hop and tire smoke, I was already in the 1.9's using my two feet so I went back to that.
To Launch control
