Shifter box install
Old Oct 22, 2011 | 10:46 AM
xgto's Avatar
xgto
Default Shifter box install
Installing a new shifter box, old unit was shot. Torque spec says 22ft lbs on the bolts, but that much seems to almost totally compress the bushings , is that right ?
Old Oct 22, 2011 | 12:30 PM
Zoxxo's Avatar
Zoxxo
Yes. Remember that the original Z06 box had *no* bushings and that was considered to be ok by the engineers. So the desired cushioning effect is a minimal one. You don't want any movement as you do your work with the thing but you do want internal vibrations (at frequencies that you'd never generate yourself) damped.
Z//
Old Oct 22, 2011 | 12:34 PM
xgto's Avatar
xgto
My car is just an 05 Z51. The old shifter box rubber bushings were totally destroyed so I never got to see how compressed they should be. At 22ft lbs they are really squashed down.
To Shifter box install
