CEL and "Service Traction System"
Old Nov 7, 2011 | 12:01 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Dirty Howie,
We really do love to see posts like this. Let me know if there's anything else I can do to help you out.
Chevrolet Customer Service,
Justin
Originally Posted by Dirty Howie
Justin
I have always been happy with my dealership (Paradise Cheverolet in Ventura California). I'm sure they will get to the bottom of this. But since they just put a new GM engine my car I know there are some might be some little gremlin causing this such as a bad wheel sensor or shorting wire. My SR is off for a few days so I am going to call the SM and see what he thinks and make sure its safe to drive my car. It sure feels good to have it back and with a brand new motor as well.
It is obvious to me by your presence and GM's warranty policy that you guys really care about us customers. I'm sure GM is winning many life time customers ( I was already one before, this is my 6th Vette)
GM
DH
Old Nov 7, 2011 | 12:41 PM
WhippledSilverado's Avatar
WhippledSilverado
I swapped my plug wire, plug, injector and coil with other cyl's and still have the same problem. I'm getting a Cyl 1 misfire mainly, very few on other cyl's and basically ruled out the above by swapping.
Old Nov 7, 2011 | 04:22 PM
Dirty Howie's Avatar
Dirty Howie
Originally Posted by Chevy Cust Svc
Dirty Howie,
Justin
Waiting to see what they found. Hope I get it back tonight, the Chevy Cobalt is quit a step down (although, I have to say it has some spunk!!)
DH
Old Nov 7, 2011 | 04:54 PM
Dirty Howie
As I said in the previous post a misfire code will disable Traction Control. Misfire could be a spark plug wire issue.
My right side cat has the same code after the engine replacement. Been driving with it that way since 10/11/11 and haven't seen a Service Traction Message. Have been waiting for parts for over a week.
Bill
Well, I was just told that the CAT will cause the misfire which will cause the DIC message and TC dash lamp.
And the reason I can cause the DIC message/Lamp to come on in a moderate turn is that I am activating AH which then sees there is a problem ?????????????
Is GM covering the CAT through the motor replacement or GMMP ??
DH
Old Nov 8, 2011 | 01:22 AM
Dirty Howie
Well my passenger side CAT is being replaced but have to wait till friday for the parts .........
Had to wait days for the throttle position sensor too.
Sure doesn't seem like there are many parts for this car around. The engine was easier to get !!!!
DH
Old Nov 8, 2011 | 09:56 AM
Dirty Howie
How big a job is it to replace the CAT?
Does the exhaust need to be removed from the heads?
Does the front cradle need to be removed and a new alignment done?
DH
Old Dec 2, 2016 | 08:31 PM
KyleDreher01's Avatar
KyleDreher01
8th Gear
So I changed out my multi function switch and now my Service Traction System light is on? Any ideas? 1997
Old Dec 16, 2016 | 02:40 AM
DMONSVETTE's Avatar
DMONSVETTE
DH
Should be four bolts and the o2 sensor. Exhaust does not need to
be removed from the heads. Cradle does not need to be removed.
Old Dec 16, 2016 | 03:28 AM
DMONSVETTE's Avatar
DMONSVETTE
Cats should look like these
Old Dec 16, 2016 | 03:01 PM
Dirty Howie
Thanks but this was 5 years ago. I don't even have that car any longer.
DH
