header installation
Old Nov 11, 2011 | 08:48 AM
motolawson's Avatar
motolawson
Default header installation
Just wondering how long it should take to remove stock exhaust manifold and h pope and reintall headers and x pipe. I did the Axel back in an hour.....thnx. any issues I should look for???
Old Nov 11, 2011 | 08:54 AM
FloydSummerOf68's Avatar
FloydSummerOf68
4-5 hours
Old Nov 11, 2011 | 10:43 AM
motolawson's Avatar
motolawson
I'm only putting front o2 sensors on my no cat system and plugging rear holes. Will the car run ok untill I can run out the trouble code
Old Nov 11, 2011 | 10:57 AM
FloydSummerOf68
Yep, it'll run fine.
People go months before tuning for headers.
Old Nov 11, 2011 | 11:30 AM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
OP, check the stickies on full writeups at the top of the page. Everything you need to know.
Old Nov 11, 2011 | 06:42 PM
Tim Coltrain's Avatar
Tim Coltrain
Default Time
I had mine jacked on block started bymyself and had the whole system off in 2hrs 15minutes.
TIM$VETT
Old Nov 11, 2011 | 06:50 PM
motolawson's Avatar
motolawson
How long to reinstall?
Old Nov 11, 2011 | 07:31 PM
Paul Slonsky's Avatar
Paul Slonsky
Default Thank you all!
I installed the MGW unit last Sunday afternoon and it is awesome
compared to the stock set up.
I was going to install a Hurst unit but all of you suggested I go with the MGW unit and it is as everyone stated!
The MGW unit greatly reduces the lever movement when shifting and is a top quality made item when compared to the stock unit.
My install took me longer than expected but now could cut the time in half since I installed the first unit.
Thank you all again for the info on the MGW unit!
Old Nov 11, 2011 | 09:40 PM
jpee's Avatar
jpee
??? I thought he was asking about a header install not a shifter.. or did I misunderstand your reply ??
Old Dec 30, 2011 | 02:09 PM
ryker's Avatar
ryker
Is the ls motor easier change headers compared to the lt1. I put headers on my Camaro lt-1 and it was a head ache. Had dent some of the primaries so a bolt would fit. Had to grind down a wrench so it could fit on the bolt and between the primaries.
Old Dec 30, 2011 | 02:29 PM
timd38's Avatar
timd38
Here is how I solved the o2 issue.
http://www.o2simulator.com/index.php...&products_id=9
Call Casper and they will just sell you the ends.
http://www.casperselectronics.com/st...oducts_id=1267
Old Dec 30, 2011 | 06:42 PM
Danne_83's Avatar
Danne_83
Hii i need some o2 extensions for my longtube headers install with catted x-pipe what will i need?? My car is an ls3
Old Dec 30, 2011 | 06:48 PM
timd38's Avatar
timd38
Casper can make you any length you need.
Old Dec 30, 2011 | 07:00 PM
madmax4499's Avatar
madmax4499
just did mine, came with 24" extentions, i would get longer if you have that option. 30" would work great.
Old Jan 1, 2012 | 11:07 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Take about 2 hours to install headers and x-pipe. C6's are much easier than C5's.
To header installation
