Help with fuel injectors
Old Nov 17, 2011 | 03:14 PM
EricT's Avatar
EricT
Default Help with fuel injectors
I slowly gathering the parts to do a head and cam swap and need some advice on which fuel injectors to get. My MN6 LS2 will have PRC 2.5 LS6 heads and a medium size cam. I can get a set of Bosch 47lb injectors for $250, or a set of Fast 46lb injectors for $340. Can anyone tell me if the Fast are worth the extra money or are they pretty much the same?
Regards, Eric
Old Nov 17, 2011 | 03:45 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I have a set of FAST 57# injectors unopened that I can sell you for less than the cost of the FAST 46#. I was going to do a big cam setup but opted into forced induction instead.
They're direct swaps for the LS2 if you're interested.
Old Nov 17, 2011 | 04:31 PM
EricT's Avatar
EricT
Thanks Floyd but, that's probably too much injector for my set-up. I'm looking at Texas Speed's 228R cam (228/228 .588"/.588") or something similar in size. Appreciate the offer though.
Old Nov 17, 2011 | 10:32 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: If you have an LS2, I would recommend adding the FAST intake to your build. Take a look at my FAST tread. I have Fast 33# injectors on my build. http://forums.corvetteforum.com/c6-t...st-intake.html
Old Nov 17, 2011 | 10:38 PM
C7&7's Avatar
C7&7
Those aren't too big. Would leave you room for growth . Great price to. I run the fast 46s and they work great.
Old Nov 18, 2011 | 09:05 AM
EricT's Avatar
EricT
I'll definitely add a Fast 102 later, just can't afford to now.
What if any are the disadvantages of running too large an injector?
Old Nov 18, 2011 | 09:16 AM
C7&7's Avatar
C7&7
I can't think of any really, If you're talking about just going up to a 57# injector. Tuning would probably be a nightmare on say an 80# injector or something crazy like that on a NA car.
If you ever want to go FI then the 57 would be a good choice. You might even need bigger for FI. I think the A&A kit comes with 60#.
Just a NA H/C/I car you can get away with 37s or 42s or 46s.
Old Nov 18, 2011 | 11:38 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I think the stock injectors will handle around 480-500 rwhp
Old Nov 18, 2011 | 12:48 PM
EricT's Avatar
EricT
Thanks for the info
This is where I'm confused, some tell me I'll need to upgrade them and some tell me I'm fine with stock. I'm only looking at 440-450rwhp with my set-up. How is duty cycle measured?
Old Nov 20, 2011 | 11:48 AM
Neumonic2002
I am around 460 rwhp, last dyno was 452 with a base tune. I have performed a couple additional mods plus a re-tune since and my duty cycle is around 83% currently.
I am installing some Trick Flow "as cast 220 heads" and will try to retain the stock injectors, we will see just how much the LS2 injectors can handle in the next 2-3 weeks.
Old Nov 20, 2011 | 12:00 PM
C7&7's Avatar
C7&7
It is good practice to stay below 80% duty cycle on a fuel injector. Most heads and cam 475-500 rwhp cars should change injectors. In my experience everyone sticks with stock injectors on cam only <450 rwhp, but when they do heads the injectors are changed. It is pretty good insurance IMO. You don't want to get on the dyno and run out of injector.
Old Nov 20, 2011 | 05:25 PM
taken19's Avatar
taken19
Track Junky
I was at 89% duty cycle on my LS2 injectors at 384 rwhp (12.7 AFR). Stock LS2 injectors will max out around 425-450 rwhp. On the other hand, LS3/LS7 injectors (42#) are good to 550 rwhp or so. I currently have 485 rwhp with LS7 injectors and am at 76% duty cycle at 12.6 AFR.
You can pick up used LS3/LS7 injectors around $200. If you decide to go that route, you will need spacers but make sure to get top spacers (as opposed to bottom spacers).
Old Nov 20, 2011 | 09:18 PM
Neumonic2002
not sure why your car was running at a higher duty cycle % than mine at a much lower rwhp, is my combo more efficient? I am running 12.5 AFR
Old Nov 20, 2011 | 09:31 PM
taken19's Avatar
taken19
Track Junky
John, don't know why we are/were so different on duty cycle. I have heard from several dependable sources that the stock LS2 injectors are only good to 450 rwhp at best and that is pushing close to 100% duty cycle.
You sure you are still running the 33# injectors? Maybe Dave hooked you up during a recent tune? I thnk it would be a tough sell to believe your 460 rwhp is THAT much more efficient than mine at 384 rwhp, but I guess stranger things have happened in the world of cars...
Old Nov 21, 2011 | 08:16 AM
FloydSummerOf68
I got them that size to cover ever switching to E85
If you change your mind, just let me know.
Old Nov 21, 2011 | 09:40 AM
Neumonic2002
I just heard back from Dave, need to clear up my fuzzy memory (my apologies) I was at 83% when I was putting out 399/403. I am at 90% according to our last tuning session but I don't have a rwhp number from that, I can say the car was making more power than when I dynoed the car at 452 rwhp with a base tune. The other change I made besides the tune was going to an LS7 MAF installed in a Vararam MAF coupling/tube.
Old Nov 22, 2011 | 12:57 PM
DeatschWerks's Avatar
DeatschWerks
Just to give you an idea on what we recommend for our injectors based on testing and in-car results...
We recommend IDC's be kept under 93%. Above that, the injectors are essentially static (100% open).
To Help with fuel injectors
