Oil Pressure question on 2012 GS
Old Nov 21, 2011 | 12:30 PM
MarkDFW's Avatar
MarkDFW
Default Oil Pressure question on 2012 GS
I have an automatic with paddle shifters. Normal driving pressure is between about 37 - 50, depending on whether I'm on or off the gas. When I floor it, it goes to 80, which is as far as the gauge goes. Is that normal when you get on the gas hard? Or should it max out at lower level?
Old Nov 21, 2011 | 01:21 PM
DRLC5's Avatar
DRLC5
I have an 11GS With auto trans. When cold I have see 60 to 65 but once warm it stays in the 35 to 50 range. Under hard throttle I have seen 55 to 60 but never max at 80???
Old Nov 21, 2011 | 01:46 PM
LucaBrasiAZ's Avatar
LucaBrasiAZ
i have a manual GS with the dry sump and i see 70-80 all the time, especially when the oil has yet to reach normal operating temps. Yours seems a bit high to me being a non dry sump. I would check the oil level and if it still bothers you take it to the dealer, or better yet go drive another GS with auto and see if the oil pressures live in the same area.
Old Nov 22, 2011 | 04:32 AM
blkbrd69's Avatar
blkbrd69
You dont mention your oil temp. It has a huge impact. At below 160 or so its easy to get that high a pressure. Note oil is not warm till 180+.
To Oil Pressure question on 2012 GS
